Question about Frigidaire Gellery Full Size Electric Stack Laundry Center, GLET1142CS
Frigidaire Full Size Laundry Center Model LCE-732L
Hot water trickles out very, very slowly. Removed hot water hose and the water pressure is very good.
Cleaned the lint screen and still have the same problem.
Posted on Sep 28, 2008
  • 550 Answers
Inside the hot water hose is a lint screen, check whether it is blocked
not a solution ~60%
Posted on Sep 27, 2008
Cold water fills very slowly
It's possible that sediment or a mineral buildup is in the water solenoid valve itself where you connect the hose. Try cleaning its screen, if this doesn't work, replace the part.
Feb 05, 2013 | Frigidaire FEX831CS Top Load Stacked...
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
My stackable washer/dryer laundry center no longer allows adequate flow of hot water. It was fine one load, and hasn't worked since. Now it just trickles hot water into the washer. Any ideas?
If you have checked that the hot water tap is turned on fully and the hose is not kinked or squashed at the back, it is worth while checking the hot water inlet filter. Turn the tap off and remove the hot water hose at the washer end. Inside the inlet port there is normally a little filter which should just slide out. Clean if necessary and replace it and the hose. If after turning the tap back on there is no improvement, the problem is symptomatic of a malfunctioning hot water control valve. Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Apr 07, 2011 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire Laundry Center (FGX831CS1) overflowing.
There are a few issues that could cause the overfilling...failed water inlet valve, failed water level pressure switch, hole in pressure system air hose or air hose disconnection to name a few. Need to have professional evaluate, or it could happen again. Call home insurance if there are water damages to file a claim, and they can handle it from there usually.
May 20, 2010 | Frigidaire FullFGX831C Size Stack Gas...
The hot water was a trickle, so I removed the hot water hose and cleaned the screen filter. I turned it back on and the flow was great for about 5 seconds and now barely flows at all. Worse is that the hot...
Take the hose back off more rust and dirt came through because od the volume of water going throgh the pipe and hose. When you take it off this time run some water at full volume in a bucket to flush everything out.
Reclean the screen and you will be fine...
Heatman101
Jan 21, 2010 | Washing Machines
Hot water is just trickling. where is the filter?
Turn off the hot water to the washer, remove the hose, look in the end of the hose for filter, or in the inlet to the valve.
If no filter, then prob could be low water pressure, or faulty inlet valve.
Please rate my solution.
Thanks.
Nov 22, 2009 | Amana Washing Machines
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
Kenmore 80 series model #110.26882503 fills slowly
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 12, 2009 | Kenmore Washing Machines
Washing Machines Logo
225 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
