Question about Protron PDV-288 7" LCD Portable DVD Player
Protron dvd playerpdv-288
Then u close the lid it wont play . if you hold the back down it plays , when u let it go it stops . i think its the spring . were do u get fix?
What i wanted to know is were to take the dvd player to have the spring replaced. the telephone number in the book wont go though
Posted on Sep 30, 2008
Battery will not hold a charge
The battery is defective. I could not find a replacement battery online. The player is less expensive than the cost to repair unless it is covered under warranty. IN future, donot allow the battery to fully discharge. It will shorten its life or end it completely!
Feb 24, 2014 | Protron PDV-288 7" LCD Portable DVD Player
Battery won't hold charge Protron PFV-288 portable dvd player
Tries websites like Partstore.com,Amazon.com,Ebay.com to buy another new battery or a compatible one for the replacement.
Jun 13, 2011 | Protron PDV-288 7" LCD Portable DVD Player
Battery does not hold charge. Where can I find a
I suggest to purchase another brand , PROTRON no longer on the market , it belongs now to SPECTRONIQ,and their customer service is very bad, they will tell you that the BATTERY replacement is out of stock at the moment but its on order , Ive been like this trying to get a replacement for my PROTRON for about 3 years !! AJ
Dec 01, 2009 | Protron PDV-288 7" LCD Portable DVD Player
I put an HD-DVD in my player but it keeps coming back out.
Temporarily you can hold the lid closed with your hand and press play and leave the lid after it loads the disc. But for permanent solutuion you will require to repair its lid switches,
Aug 22, 2009 | Toshiba HD-A30 HD-DVD Player
Will not play dvd
PORTAL DVD PLAY MOTOR THAT SPINS THE DISC MAY OF STOP WORKING OR THE LASER BUT MOST LIKELY ITS THE MOTOR
Jul 02, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Initial screen shows "OPEN" in the top right corner
I had this exact same problem with my Protron DVD player. It was driving me crazy. I was about to just trash it, cause I was so tired of dealing with it. Then I decided maybe I should open it up and see what the issue is. I am not sure what exactly I did that fixed it, so I will just tell you everything I did. It works great now!! It's as if I know what I'm doing... but I was just playing really.
Here's what I did:
I unplugged it, took off the battery pack, turned it over and unscrewed the four screws holding it all together (one of the screws is located under a sticker that warns about voiding the warranty). Then I turned it back over, lifted the screen back and pulled apart the top from the bottom. It did kinda sound like something might crack as I pulled it apart, but it didn't. I just moved slowly and eventually got the entire thing separated, even the plastic around the hinge area will pop off, leaving just a couple cables connecting the top to the bottom. Again... I am not sure what I did that fixed it. But I found the button that would be located under the right small hinge of the DVD door that tells it if the door is open or closed. I pushed it a few times, thinking at first that something might be missing or broken that should make it work. I blew it out (just because it was opened up and I thought it couldn't hurt). I did notice a small white plastic piece near the back that fell when I had pulled open the entire thing. I thought it had to do with dvd door, but then realized it was the control that told the player if the lid was up or down. It had a wide side and a skinny side, with a flat piece in between. The skinny side actually sticks through the top section I had just removed. It shouldn't have had anything to do with the other problem, and it could have been in place just fine before I opened it up. I did put it back through the hole, using a piece of tape to keep it there while I assembled the entire thing back together. And then I was excited. I fixed it. I'm not sure how, but at least I don't need to buy another one. I don't know if it was me blowing it out, replacing that plastic piece, or playing with the dvd door open button. I would think it is the latter. (when it all apart there are two little black buttons near the back. one is just right of center, and the other is another inch or so to the right of that. the first is the dvd door open button, the furthest right is the one that lines up with the white plastic piece and the hole for lid open or closed).
That is probably really confusing. Sorry. I just explained as best I could. Let me know if further explanation is needed.
Jun 20, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Looking for repacement parts for jvc karaoke player Model # xl-mv303bk
hi
you can try here see if jvc can help you out, or point you in the right direction.
which parts you need ?
riz.
Apr 20, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Protron PDV-288 7" LCD Portable DVD Player Logo
49 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
