Question about Haier HDN655E Dehumidifier
Not dehumidifing my room...no water in bucket
  • sjms Oct 16, 2008
    my haier was running ok all of a sudden it quit collecting any amount of water but it is still running????
Check the filter. I had the same problem. I checked the filter and found it quite dirty. I cleaned the filter and now it is working properly.
Posted on Oct 27, 2008
The dehumidifier is running but no water is in the bucket. Should the setting be on low humidity because that is what I want or should it be on high because that is what I want to take out of the air?
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 05, 2010 | Haier HD656E Dehumidifier
Water not collecting in the recovery tank
Jan 03, 2010 | Dehumidifiers
Dehumidifier runs but does not remove moisture.
Jan 02, 2010 | Danby DDR6588EE Dehumidifier
Makes a crackling sound while running
Jan 02, 2010 | Whirlpool 75-Pint Dehumidifier
My dehumidifier runs, but no water is collecting. Humidity in the house is about 57%. The unit is only 3 months old.
Jan 01, 2010 | Kenmore 5230 Dehumidifier
Ebac 2850 made rumbling noises and shook now not working at all
Jan 01, 2010 | Ebac Dehumidifiers
Spitting water out of vent. dehumidifier is has drain hose set up.
Dec 31, 2009 | Dehumidifiers
Runs, but no dehumidification. 6 months old.
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 30, 2009 | Haier Dehumidifiers
Not collecting water
Hi..my name is Keith..and your unit has lost is evaporation/cooling capabilities...and its usually do to a freon leak..or the compressor has went out...i would suggest you buying another dehumidifer..i wish i had better news..i hope this has helped and im not always 100% correct..write back with any questions and i will try to help
Jun 29, 2009 | LG DH404E Dehumidifier
Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Aug 02, 2006 | Danby DDR583R Dehumidifier
Haier HDN655E Dehumidifier Logo
136 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Youngman
Michael Youngman
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
