Question about Brother MFC-9440CN Laser Printer
Print unable error message
My MFC 9440CN gives me "Print Unable 3A See Troubleshooting and regular maintenance users guide" message when i try to start it up. The only problem is there is no 3A in troubleshooting guide. can anyone help, please?
    Novelist:
  • Brother Expert
  • 297 Answers
Showing my 7220 Brother printer gives me the message "Unable to print, See troubleshooting and general maintenance in User's Guide" please help me
You need to pres Menu-Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press the Up Arrow and numbers will change and press OK after the one you want to select. The number sequence is the following. 8-0 2-8-6-4 4-4-6-0 7-7 9-9
Oct 27, 2014 | Brother MFC 7225n - Multifunction fax /...
My printer Brother MFC-9440CN is unable to print. The message showed on display as"Print unable 28, See troubleshooting and Routine maintenance chapter in User's guide". I have cleaned the...
Hi there !
I am here to help you to solve your problem.
I believe your print spooler service stop running or your spooler is confused pending some queue at the print spooler service.
To resolve this, follow this procedures.
Go to START MENU
Choose RUN (For Windows XP) or Choose Commamd prompt, right click mouse and run as administrator ( For Window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Jan 27, 2011 | Brother MFC-9440CN Laser Printer
Brother mfc-7420 - unable to print
OK Try
Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the best
Jan 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
IT DOESNT ALLOW PRINTING AS IT SAYS "unable to print review users guide troubleshooting' HOW COULD I SOLVE THIS PROBLEM
Did you install the drivers correctly?
What program are you using?
How are you trying to print?
Are all the cables plugged in?
Is the printer on?
Sep 25, 2009 | Brother MFC-9440CN Laser Printer
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
UNABLE TO PRINT BROTHER MFC 210C
Go to this link and find Page 11-4 in the section on Troubleshooting:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Let me know if this has helped you to solve the problem. Binary Bob
Dec 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 9420cn "unable to print see troubleshooting...users guide"
ctstore,
Your unit requires replacement of its maintenance kit. You will not be able to do this by yourself unless your are a technician, which I assume you are not. The cost for this repair will not be cheap, you are going to be up for over $500 and you need to do it through a brother warranty service centre.
Gremlin11
Sep 25, 2008 | Brother MFC-9420CN All-In-One Laser...
Unable to print
ph is defective and needs replacing (4F: thermo sensor within ph)
Mar 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-9440CN Laser Printer Logo
629 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
