Question about Epson RX620 All-In-One InkJet Photo Printer
How to scan negatives & slides with the epson RX620
I'd like to scan my negatives & slides but can't work how to do it. I don't find the instructions in the manual very helpful.
Do you know if there's a tutorial for this? It would have to be step-by-step in picture form as I just can't do it otherwise!
  • Anonymous Mar 13, 2009
    it scans negatives, but the resultsre far too dark
There are holders for the slides and negatives inside the top cover. Remove the white part and take out the holders. Place the slides or negatives in the holders and place on the glass plate. Then you choose the proper menu for copy or scan and follow the directions on the screen. I scanned quite a few slides and had no problem.
Posted on Nov 20, 2008
  • lindadoherty Jan 07, 2011
    i followed the intsructions exactly but it said that it didn't recognise the film
  • David Crisp Nov 05, 2011
    I was able to scan my negative, but the image is unusable in its current form. IF I wanted to create a photo from the scanned negative, I see NO way to complete that task. AND THAT IS THE WHOLE REASON FOR SCANNING THE NEGATIVES!!
Can not scan negatives and slides
Download this manual and select "scanning films and transparencies" section and follow the instructions.
https://files.support.epson.com/pdf/prv7ph/prv7phug.pdf
Aug 07, 2014 | Epson Quality V700 Photo Scanner
I need an all in one printer that also has a negative scan facility. Any suggestions, I have 2000 slides to scan .
Do you want a recomendation?do you want new or used? Typically all in one users don't scan slides or film, but flat prints, so they don't have the lighted back lid needed to scan film.I know that the Epson Stylus PHOTO RX-620 & 700 had a holder for 4 slides or 1 strip of film about 8 inches long
Sep 01, 2012 | Epson Office Equipment & Supplies
Can HP psc 1410 PRINTER SCAN NEGATIVE AND SLIDES
Chances are that somewhere in your family photo collections you have a bunch of slides and negatives that you wish you could do more with. You may want to include them in your family history, to publish them on the Web, or simply to make digital copies so you can share them with the family.
If you've ever tried to scan a negative or slide on a regular flatbed scanner, you'll know that it doesn't work, and you end up with a pure black scan. In this article we'll show you how you get your negatives and slides into digital format, and what issues you may face along the way.
pixblue.gif Benefits Of Scanning Film
There are some key benefits to scanning film (we'll use the term to include slides and negatives) in comparison to scanning a photo. When you scan film, you can use the full area of the slide or negative, whereas a photo will generally only display a cropped portion of the original. You are also scanning the original source image rather than the color corrected and tweaked version of it that the photo processor has provided you with. The process of turning a negative image into a positive one involves inverting the colors in the image and removing the orange cast from the negative. This would be a complicated process if you were doing it by hand; however, your scanner will provide you with software to do this automatically, or you can purchase standalone software to do it.
Most cheaper flatbed scanners are designed to scan photos and other images that reflect light when it is shone onto them. The problem is that film is transparent and light passes through it rather than being reflected off it. Many flatbed scanners have an optional transparency adapter, which replaces the scanner lid with a larger box shaped ob....
Jun 09, 2010 | HP PSC 1410 All-In-One InkJet Printer
I am looking for instructions on this product.
Step 1: Open the scanner lid and remove the Transparent Materials Adapter (TMA).
Step 2: Place your slides or negatives into the appropriate template. Follow the orientation indicated by the icons on the template.
Step 3: Tip: If you are scanning fewer than the maximum number of negatives with the TMA, cover the empty spaces with the provided light shields to avoid letting any extra light in
Step 4: Place the template on the scanner glass, aligning the arrow on the template with the indicated mark on the scanner bed.
Step 5: Close the scanner lid and press the Scan Film button (or select the Scan Film option if you're using the HP Solution Center application on your PC).
Step 6: In the Scanning from dialog box, click Change Settings.
Step 7: Under Scan Shortcut Settings, select your Scan Type (either Negatives (TMA) or Slides or Positives (TMA)).
Step 8: Under Scan To select Save to file. Then click Scan.
Step 9: Under the Save Location dialog box, click Browse and enter the destination folder of your choice. Click OK and follow any on-screen instructions to finish scanning. The scan will be sent to the destination folder you selected. s.gif s.gif
May 01, 2009 | Office Equipment & Supplies
I am tring to scan my 35mm negatives
Select scan. When the window pops up look in the upper right hand corner of the window. You will see select source: drop down menu give you choices which includes negative film. Just select it. Then drop negatives into holder. Oh, make sure you remove the cover sheet that slides in and out of the cover.
Mar 19, 2009 | Canon CanoScan 5000F Flatbed Scanner
Slides scan as negatives
this scanner usb cabal no didact tell me bored problam ya cabl problam 6600E
Feb 04, 2009 | Canon CanoScan 4200F Flatbed Scanner
CanoScan 4400f
Keep the protective cover on except when scanning slides or film.
Jan 27, 2008 | Canon CanoScan 4400f MultiFunction Color...
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Jan 22, 2008 | Epson Perfection 3200 Photo Flatbed...
Unable to use film adaptor
1) In the program you are working from, begin the scanning process. If working in full auto mode, as the scan begins you will see a message that reads TO CANCEL SCANNING IN FULL AUTO MODE AND SWITCH TO MANUAL MODE, CLICK CANCEL. At this point, click CANCEL, then MANUAL MODE.
2) You will now see all Epson Twain settings displayed. If the scanner has not previewed automatically, click the full page preview button (icon of a paper with one corner folded down).
3) Ensure the settings on the right hand side of the Twain are correct. For example, the DOCUMENT SOURCE for transparencies must be either TPU: COLOR NEGATIVE FILM, TPU: MONOCHROME NEG or TPU: POSITIVE FILM.
FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes. (If you are scanning a black and white slide in true colors, choose TPU: POSITIVE FILM as the DOCUMENT SOURCE and BLACK AND WHITE PHOTO as the IMAGE TYPE.)
If the DOCUMENT SOURCE is flatbed, the scanner will not activate the backlight in the transparency unit. If the DOCUMENT SOURCE is greyed out and you cannot select a TPU option, close the twain, reseat the power/communication cable connecting flatbed to TPU, then re-open the twain and try again.
4) Ensure the other twain settings are correct for the type of scan you are doing.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no guidelines on this; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing an AUTOMATIC THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, click the CONFIGURATION button and uncheck AUTOMATIC THUMBNAIL PREVIEW FOR FILM, then OK, and try the PREVIEW button (page with corner folded down) again.
In this mode, you will have to manually marquee or crop the slides you wish to scan. Use the left mouse button to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process (manually crop then scan) for as many slides or filmstrips are on the bed.
Aug 16, 2007 | Epson Perfection 1200 Photo Flatbed...
35mm Color Slides
Here they are for Mac and PC
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
Mar 15, 2007 | Epson Perfection 3170 Flatbed Scanner
Epson RX620 All-In-One InkJet Photo Printer Logo
1,816 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
