Question about Bosch Washing Machines
HO DO YOU FIT BRUSHES TO A WFR2866GB WASHING MASHINE
  • 550 Answers
Remove motor,
remove motor brush cover screws from the motor
shake out old brushes
insert new brushes, spring side out
install brush cover screws
install motor
Posted on Sep 27, 2008
Asko W640 washing mashine !!! Got "engine failure" as an error message on the display and the mashine did not work. I changed the brushes and now the mashine is running until end of the...
You have to change the hose at the top of the drum and you need to polish the commutator in the motor - I removed the motor, took the brushes off, stuck the pulley in my lathe chuck, supported the motor housing and polished the commutator with a little 1200 wed and dry and some wd40 - seems to have fixed the exact same problem as yours.
Jul 25, 2011 | Washing Machines
How do you release the tension bolt to fit the belt on the washing mashine
To fit the belt it is not necessary to release the tension bolt. To remove the belt use a long screwdriver. Put it between the belt (sideways) and the large wheel, lever the screwdriver to outside while moving the wheel in clockwise/anticlockwise depending upon where you put the screwdriver at left/right side. Reverse the procedure for putting the belt on the wheel. While putting the belt first fit it on the motor pulley.
sonsunny
Jun 30, 2011 | Washing Machines
Hello, My washing machine MW 6152W instuction guide can't find it and my washing machine is now on but doesn't spin at all for nearly 8 hours now. Please help me to get my washing mashine work.
hello check the pump first it has drain water out first before it spins if the pump is ok then check the module board this controls the motor speed if this ok the brushes on the motor can cause it not to spin hope it helps
regards
shaun
Mar 20, 2011 | Washing Machines
10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Jun 15, 2010 | Miele 300 Front Load Washer
Beko wma 1512 s washing mashine not spinning
I've just had the same problem, replaced the brushes and the problem was still there, i then cleaned out the filter, it was really clogged up, this fixed the fault, you will also need a couple of towels to soak up the water from the filter, if the machine can't empty all the water from the filter it stays there and will not move on to the next cycle thus making you think it may be a pcb fault, please clean the filter before spending money on new brushes and/or new module or getting an engineer out to it at cost to you, please also ensure you remove the plug from the wall socket before you attempt to fix any electrical appliance,
Feb 01, 2010 | Washing Machines
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Fixing new brushes
To fit new brushes to Hotpopint, you need to remove the rear panel if the washer.
There you will see the motor. remove the motor and fit the new brushes
Mar 27, 2008 | Hotpoint First Edition FEW10P Front Load...
Washing Machines Logo
134 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
