When you turn push the power button the red light goes on and off and nothing happens. can't eject cd in there.
SOURCE: A DVD got stuck in the dvd player
unplug dvd player, hold down open button, then while continuing to hold down open button, plug dvd player back in.
SOURCE: my toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
SOURCE: screen will not turn on, power light flashes red
try checking first your tact switch or your power button, then next look for open fuses or low ohm resistor on secondary part of your power supply then check your horizontal and vertical outputs for shortage and open circuits check also your horizontal drive stage.
SOURCE: I tried to eject a DVD and now the DVD holder is
if you had forced it open its probably not aligned (if its still open give it a little shove and press the eject again (otherwise unplug the machine for 5-10 min..and try pressing the eject button again
SOURCE: My Toshiba VCR & DVD video recorder model
A temporary solution would be to use a paperclip to eject it; usually, any disk drive has a little hole that a paperclip can be stuck into which forces it to eject.
