Question about Konica Minolta magicolor 2400 Laser Printer
Paper Feed errors on 2400W
I have a 2400W that will go through spells of not feeding paper correctly. It will feed the top sheet half way in where is looks like it is designed to pause to be picked up by the next feed process as the drums do their thing. At this point it will stop and generate a paper jamb error. I have to open the top pull out the transfer roller assembly and remove the sheet of paper and close it back up. It will do this several time in a row some time 8 or 10 times before it will finally decide to feed properly. It will then feed fine for a short while and then start over again. I have tried different papers and flipping the paper over and end for end with no real consistent results. Any Ideas?
  • 2 more comments
  • Anonymous Oct 02, 2008
    same issue
  • don94403 Oct 03, 2008
    Same here. I also commented on the same problem posted by someone else.
  • Anonymous Dec 02, 2008
    Paper won't feed at all, or at best, will take half sheet half-way, then begin the error flashing. Used towork very well, but always required coaxing!
  • Anonymous Jan 19, 2009
    i have the same problem
Thanks to the Konica Minolta tech: Solution is to use alcohol and a clean wipe or cue-tip on the grey 1/2 moon roller deep inside at the end of the paper feed tray. It is accessessible easily by lifting blue top cover of printer, then pulling out the ink cartridge. There will be a grey 1/2 moon like roller seen when looking at very bottom of cavity. Clean the dust off and all will work fine. You can manually roll the roller to get all faces. The machine will reset it's position so it is not nessary to set back to original position.       Turn the machine on with or without paper. Once the roller has reset it's position, gently push the load of paper into the paper tray to be sure the roller was not keeping the paper from being placed to furthest position toward back of tray.
     All is ready for reliable printing once again! Best regards, Danny
Posted on Jan 12, 2009
  • 3 Answers
It is a timing issue, mine does the same thing. Here is fix. Open top door, remove drum cartridge, look inside for pickup roller ( the one that is shaped like a half-moon) reach down there and rotate it towards the front of the printer and downward so the curve ends up being pointed down to the bottom of the printer. You should here a loud click, that is the cam being reset. The cam is to the left behind the 2 gears. remove any paper feed jam, reinstall drum and close the top lid. This should reset it back correctly. Do the above steps with paper in tray and the power left on. Do not reset the printer after resetting cam position. Also it might take a few attempts to get the timing reset right, so dont give up after 1 failed attempt. I have had to do it 10 times before to get the timing right. Just make sure the curved area points downward.
Posted on Dec 03, 2008
  • 118 Answers
Over time time the feed rollers get covered in paper dust and toner and such. They then will slip while pushing the paper, and it does not get all the way to the sensor to say the paper is ready. Just carefully clean them with a little Fantastic or similar cleaner.
Posted on Nov 18, 2008
  • Dan Hudson Jan 03, 2009
    One other thing I have seen with these printers is the paper tray not lifting to the rollers. I have had to either trim a little plastic that was rubbing, or take the lift spring out and stretch it to give it more lift. On one printer, I found the metal frame was out of square so the tray would not lift.
Thanks for offering that help, but in my particular case, it was shutting down before even lifting the paper so that the feed rollers could reach it. I am pretty sure it was something else this time. When I found out how much it would cost to have it repaired, I decided to just buy a new printer. I'm quite satisfied with my HP Color Laserjet CP 1215.
Epson Stylus CX4800 prints blank pages
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
Printing doesnt start at top of page
Sure the paper is correctly document may be the printer thinks the paper is metric instead of inch check the printer setting
Jul 12, 2012 | Minolta magicolor 2400W Laser Printer
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
1 Move the paper lever to the position marked "REAR."
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
E2 error code on Xerox work centre xd series 120f copier
e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
Nov 05, 2009 | Xerox Office Equipment & Supplies
Paper feed issue
You didn't setup the paper size correct, check again in the driver and application to have the same dimension with the actual paper in printer.
Reset your Toners and Imaging units for Bizhub and CF series.
Jun 04, 2009 | Konica Minolta magicolor 2400 Laser...
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Paper doesn't feed
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Jan 12, 2009 | Canon Office Equipment & Supplies
Hi! Have you checked the correct source for paper feed? you can use either sheet fed paper tray at base of printer and from top loose sheet feed. Make sure selection is correct, button below/to right of pwere switch.
Hope this sorts it, it did this on mine.
Paul 'W'
Dec 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Konica Minolta magicolor 2400 Laser Printer Logo
822 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
