Question about Sanyo DRW-1000 DVD Recorder/VCR
Snowy screen when I play a DVD
After Direct TV came out and changed out DVR box, the DVD burner says it is recording, but there is no picture on trying to playback, only snowy screen. I am sure it is a problem with getting the "input" correct, but I have tried everything! Direct TV says it is my problem, not theirs.
Thanks!
  • flyingbunny Sep 27, 2008
    ok, I am pretty much electronic illiterate, be very specific, please. Changed out the Direct DVR box and now my DVD player doesn't show a picture on the TV. Counter shows that it is recording and playing, but cannot get it to show on the tv screen.
    Genius:
  • 1,447 Answers
Hi-
reconnecting the cables and make sure they are tightly plug in, try to do a hard reset on the receiver by pressing on the front button on front panel for 5-7 seconds, if there is no power button, unplug it for 15 mins then replug it, then try recording again. If all fails then its the DVR you are having issue with.
Hope this helps
Posted on Sep 27, 2008
  • Sanyo Master
  • 19,396 Answers
You need to program the DVD RW in the right way to record from DVR box.
Connect DVR box to DVD RW input port, then DVD RW output to tv.
Then set the DVD RW to record from aux channel, or line in or AV channel, depending on what cable connection you are using.
  • Ginko
    Ginko Sep 27, 2008
    In detail , static signal (snowy screen) means that the DVD RW had recorded on a channel with no reception.
    Probably the DVD RW had been set to record from one of the channels that is not the one where you connect the box, and receive the box signal.
    Tune up the TV on the DVD channel then explore dvd channels untill you find box signal on DVD, it will be on one of the input channels.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
try to change the cable!!!
may that helpS :)
I'm using a coax cable from symphonic vr-701 to tv and trying to record. it acts like it is recording but just shows snowy image on playback
Coax from wall to coax in on VCR and Vcr Coax out to in on set.
Whatever channel vcr is on this way it will record and pass to set.
Check first you have playback from VCR to TV alone, could have dirty or blocked video heads which in record will just record no watchable picture. Hookup or blocked video heads are most likely.
Dec 13, 2012 | Symphonic Televison & Video
DVR
yes but it will depend on memory of the cd in order for it to be a succesfull burn
Aug 10, 2008 | Philips DSR704
Jumping picture on playback on TV DVD player
Try using another brand of DVDR (cheap ones tends to cause porblems in regular DVD players) and burn at a slower speed.
Nov 24, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
Since today i have had a snowy sound On channels 1-5 the picture is there, they are ok on just normal tv and they are ok through a vcr but not dvd recorder.....i have tryed settings,changing scart...
Hi, Unfortunately I am a bit unclear on the snowy sound issue but what your describing otherwise sounds like you are trying to watch tv via the dvd recorders built in t.v. tuner, this is possible usually just with a coaxial connection. ( a cable tv cord ) The out to t.v. terminal on back of recorder must be connected to the in from ant./cable on the back of the tv set. all other connections are for higher definition playback. Thanks for trying FixYa, I hope this helps, and good kuck-Prodzilla
Apr 13, 2011 | Televison & Video
Will this burner work on dual layer discs?
Pioneer has released Firmware for the DVR-107D DVD Writer and DVR-A07XLA & XLB DVD Writer. This release # is 1.18.
http://www.pioneeraus.com.au/computer/firmware.html
(a ZIP file download, but uncompresses to an .EXE, as does theflashman.rpc1.org site download. I can't uncompress the EXEs with Stuffit (standard) Expander v7.0x here, but Scott said he used version 8.0.2 )
Looks like we are getting closer to Dual Layer Support:
(although some have flashed NEC ND-2500A drives to DL 2510 model firmware, I doubt that Pioneer will release an official firmware update for the 107D to add dual-layer burning. Like other mfrs, I suspect they'll sell a new drive model with DL burning support.)
    For Models DVR-107D FW Version 1.18
  • DVD-R Writability Improvement
  • +R Writability Improvement
  • DVD-RAM Playability Improvement
  • CD Playability Improvement
  • +R DL DoubleLayer Playback Implemented (NOT Record)
    For Models DVR-A07XLA, DVR-A07XLB, DVR-107AXL & DVR-107BXL FW Version 1.18
May 23, 2010 | Pioneer DVR-107D DVD±RW Burner
Intermittantly freezes on playback. Toshiba rs-tx20 dvr
shut down tv/dig box/dvd. unplug and then leave a little (cuppa time)
replug .then start up dig box then tv then dvd.sounds like in need of "reboot"
Sep 01, 2009 | Toshiba RS-TX20 DVD Recorder
Trying to record from TV.
TRY HOOKING THE COAX TO THE DVD RECORDER THEN TO THE TV ,BEST I COULD THINK OF.
Mar 27, 2009 | Cyberhome DVR 1600 DVD Recorder
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
Sep 28, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Sanyo DRW-1000 DVD Recorder/VCR Logo
128 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
