Question about Canon PIXMA iP1800 InkJet Photo Printer
How to correct error 5100 in canon pixima ip 1800 prnter
After paper getting jammed in the printer my ip1800 stopped working and starts flashing lights between gree and yellow. It gives error 5100 and asks to cancel the printing. Guide me as how to get the printer working again
regards and than
  • xetaxeta Oct 12, 2008
    I have the same exact problem. The paper keeps getting jammed and I get the error message too.
  • 4,041 Answers
Hi You can Try
If you still look at this web then have a go
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Service error 5100 on canon printer ip 1800
to fix this kindly follow the steps,
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 18, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800-alternating flashing lights. 1 long green, 3 short orange. How do i troubleshoot this? It is a ''Service Error 6000''. Which translates to a paper jam, however, there is no paper in the...
1- Please open the cover and inspect the inside of the printer carefully. There might be a little piece of paper or a tiny object jammed in there and is causing this error message. Also get some canned air and clean the inside of the printer. 2- Restart the printer.
Feb 12, 2010 | Canon PIXMA iP1800 Printer
Printer wont print and comes up with service error 5100
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 16, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon ip 1800 printer
hi, your paper feeder might be jammed, try seeing if your little wheels turn properly (where the paper is fed) let me know..
Sep 10, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Jul 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How can i solve the problem error 5001 of ip 1800 canon
5001 is not an error code but 5100 says that there is a paper scrap blocking the carriage, or grease on the encoder strip. The plastic strip behind the carriage assembly that runs all the way across the printer. Try first to clean the strip with a damp Q-tip just damp with water.
Jul 27, 2009 | Canon PIXMA iP1800 Printer
Canon Pixma iP1600 Printer problem
this is the service error download canon chip resetter utility, then reset your printer , download IP resetter utility
Nov 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
PRINTING PROBLEM WITH CANON IP1880
Shut the printer off. Than unplug it's power. Than unplug the USB/data cable. Wait about ten minutes. Allowing printer to reset it's self. Go to pg. 37 of your manual & follow instrctions for cleaning. Connect the power cable, the usb/data cable & turn on the printer. Test printer for error paper jam (light/display message). Canon's web site for drivers, updates, software & guides. PIXMA IP1880 is the iP1800 series.
When web sites loades you must choose your operating system from the drop-down menue.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=14991
Problem not corrected? Uninstall printer software. Re-start PC. Re-install software. Re-start PC & re-test.
Hopefully you will not need to uninstall & reinstall.
Feb 11, 2008 | Office Equipment & Supplies
Canon PIXMA  iP1800 InkJet Photo Printer Logo
495 people viewed this question
old marine
old marine
