Nikkai tv a06gl no signal on tv or radio - Televison & Video
7" Nikkai tft digital tv no signal
Check and replace its tuner. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 01, 2014 | Televison & Video
Got the Nikkai JV-TV888D had no problems at all until now...It won't tune - in and just displays 'No Signal' on the screen! Any help will be gratefully received!
Have you checked that the aerial is plugged in? Does it have an external aerial? If so is it plugged in (Socket on rear takes telescopic or external). If external have you tried aerial on another tv?
If your service is digital is it switched to Digital TV? If it's switched to analogue and you're trying to tune in it wont find signals if you're in a digital area. (or to a certain extent vice versa)
May 20, 2014 | Televison & Video
Need a tv code for a Technika LCD 1080P tv for a Nikkai universal remote control
0291,0290,0299,0296. Try these codes. If you wish to get more, check the sites linked here. It has setup codes, and setup procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 24, 2013 | Televison & Video
Nikkai mini tv not getting any signal
all tvs now need a antenna box to get channels unless they say otherwise.
Aug 22, 2013 | Televison & Video
I have a tv digisender (Nikkai) which works fine with an analogue tv on a scart lead, but not via a scart lead with a Kenmark dtv. (Error message is no signal received) Help!
you have to select scart on the kenmark tv from the source menu as your digi receiver probably does not have an av switching voltage
May 01, 2010 | Samsung WS-32M066V 32.28 inch TV
Have a Nikkai A11HJ (Distributed by Maplin, UK)
I have a Nikkai A11HJ DVD Player with a problem, it plays disk for about 7 minutes and then stops playing and reverses back to the TV, can anyone help?
Jan 30, 2010 | Televison & Video
Nikkai 2727 Video sender will not send signals from my sky+ box. The scart lead is plugged into the Video out, but even when i plug it into the TV out it still doesnt work. I know the Transmitter and...
check that you have the sender plugged into the sky box and the receiver into the required tv and not the other way round. The wrong way round still allows the controller to change channels but you will see nothing also ensure that both sender and reciever are on same channel 1 to 4
Jan 24, 2010 | Panasonic Televison & Video
I need a remote control code for my nikkai a88jb freeview box so that I can programme a universal remote control. Any ideas?
my nikkai a88jb after connected still come up with "empty data base" . no signal of anything showing and i did plug in antenas! pls what shoul i do?
Apr 18, 2009 | Televison & Video
Can't set up my new Nikkai 5.8GHz video sender.
Could be that the Scart socket doesn't pass through the signals from the receiver. I had a Goodmans TV with Scart input which just didn't respond to the receiver. When I moved it to the Scart connector on my VCR it worked a treat.
Nov 18, 2008 | Televison & Video
Need manual for nikkai a38fq car radio
I need the passcode for nikkai fm transmitter bluetooth thanks
Jul 29, 2008 | Audio Players & Recorders
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
