The disk drive on my new advent 5311 laptop will not read any disk i insert into it, instead it will just ask me to insert a cd into the drive when there already is one.
  • 48 Answers
Your disk drive cannot read cd at all, that why it keeps asking to insert cd. Just simply return back where your laptop bought. I think the have warranty of it, it will be replaced for the defective disk drive.
Posted on Sep 28, 2008
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
How do i get an advent recovery cd when one was not supplied with my laptop? The system did not reboot after restarting from installing iTunes. The recovery tools do not seem to work and the laptop keeps...
Hi
you could try to power up and press the f8 key at the same time
and go into the safe mode or
directory services restore mode
instead and delete the itunes and try to restore back a day or two
this may then be ok
its worth a go
good luck
Mar 06, 2011 | Acer Computers & Internet
I an looking for a memory stick for an Advent laptop 5311 2GB memory stick can you help please
There are lots of companies who sell this and it is very easy to replace on your laptop too. I would suggest www.ebuyer.com for cheap prices. You need to go into laptop memory section and search for 2GB DDR2 SODIMM memory
May 24, 2010 | Advent Netbook
CD ROM
The drive has NOT been able to read the directory of the disk you put in.
Possible causes:
Disk may be a DVD which your drive may not be able to read.
Disk may be a DL DVD (double layer) whcih your drive may not be able to read.
The disk might be a BluRay which your drive may not be able to read.
Your drive may be defective or have a dirty read head.
May 03, 2010 | Compaq (120192-B21) CD-ROM Drive
I own a very dated Gateway laptop 9600 and I want to transfer data to new laptop. I am attempting to download files to CDs but it is not reading the blank disk and asking me to insert disk. Is it possible...
Yes it is - but first - make sure that you have inserted the right disk (cd for cd burner). However, you only have 800 mb of available space on a cd disk to use, and I don;t know how many files you have or how big they are, so I can't say how many disks you may need. However, if your laptop has a usb port, I would highly recommend using an external hard drive instead. A 500 gb drive (made by Seagate) will run you about $125, and is well worth th investment. Hope this helps!
Mar 27, 2010 | Computers & Internet
CD Drive is not reading disks
It will cost about $30 to buy a brand-new CD/DVD reader/writer to replace your "dead" (broken laser) optical device.
Feb 16, 2010 | Compaq Laptop / Notebook Video-336970-001...
Advent 5311 laptop
Go to start, click my computer and the folder should be there to start the camera and bring it up
Feb 04, 2009 | Advent 4211c Notebook
Asked for format disk when insert CD with existing data on CD drive
There is a small possibility that your lens on the CD Player is dirty. Use a normal CD Lens Cleaner, with no solutions, and run it through 2-3 times to clean the lens. Then re-try the CD in question. If you still have problems, it may be the CD you are using, that may have been formatted wrong when initially created....
Sep 20, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
51 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
