Question about ASUS P5PE-VM Motherboard
Doesn't power on for long. (Possible Motherboard problem)
Hey there, i recently installed a new harddrive cooler fan and i think i might of corrupted it. I ain't sure though because it still loads up okay, but then powers down a few moments later when i get to the OS Desktop. Then when i try to turn it back on it stays on for a less amount of time each time to the point where it doesn't turn on.
I have tried disconnecting this new fan i bought and i get the same result. My computer by default loads up Vista 64bit, but i don't think its that because i loaded up XP too. I got a repairman coming in soon but he told me to try and figure out the problem.
The spec of my computer is a 5.5 Score on Vista
4GB of RAM (I think its DDR2)
2.4GHZ Dual Processor (Again not sure on make)
8800 Nvidea GTS 640MB graphics card
ASUS P5K Motherboard
I hope the spec i gave helps (can't remember alot of it)
I still think that the problem might be with my reinstalling of the harddrive (them being hard to put back in)
Well i hope you can help me out some what.
Thanks in advance
Sam
Shropshire England
p.s I am not sure of the exact name of the motherboard.
  • 1 more comment
  • svjkronos64 Sep 27, 2008
    hmm i just tried disconnecting the harddrive and it seems to work fineish (Apart from the fact it can't do anything)
    erm, is it meant to turn itself off when its on the screen saying you should put a harddrive in then press a key to continue??
  • svjkronos64 Sep 28, 2008
    Hmm i just had the repair guy have a good look at it, and he says the motherboard (P5K something) is being very very tempermental.
    It could be the power supply actually, because the room i have it in was poorly built in terms of circuitry and that lot, i will try it in another part of the house, i hope its this, because then i can have my computer next to the kitchen!!! :D
    kk i shall repeat the problem and try and give a clearer understanding of whats happening.
    - I turn it on
    - Choose the OS
    - Gets to the Desktop
    - Turns off about 2 mins later, relentless of what its doing
    Then the next time i turn it on it doesn't make it to the desktop. The Repairman says the Harddrive is fine and fully working.
    If the problem doesn't go away from the power supply being moved (Moving the PC i mean) then i shall try repairing the OS through the installation disk (Basically i'm doing what the computer tells me to, it says that the hardware change is causing the problem.
    Hehe, anyways, i will soldier on finding the problem.
    Thanks for the help, i hope what i've been saying helps.
    i tried the Power SUpply idea but it didn't really work ( The computer stayed on like a min longer but that could of been anything)
    Not sure what else to do but use the repair option on my OS disc.
    We'll get this cracked no worries.
    Thanks all for the help, keep at it.
Ahh all good, my motherboard was fine, it was the fact the heat sink was literally falling off the motherboard xD!
My bad all, i should of noticed the rapid increase in tempreture. Well i got it sorted
Thanks for yoiur help all.
Posted on Oct 01, 2008
    Problem Solver:
  • 10 Answers
Try having your power supply tested.Not sure if this is it but 1 one of my systems was doing the same thing!Hope this helps.
Posted on Sep 27, 2008
  • Ken Sep 29, 2008
    If the repair guy says its your motherboard and you trust them,get a new puter.I know iyts mean and expensive to say but true.Unless you can get a new baord and change it yourself.Not all that hard really.Just take your time and mark down all your connections.this is how I learned to do my own.Saves ya $100s..
I have recently made a new computer and it just wont power on i have installed all the compents right and when i push the power button the cpu fan makes a few cirles(3-10) and then stops....If I try to hit...
Hi, Check whether you have connected the motherboard controls(power_button,rest_switch) correctly.Check it in your motherboard manual and also check whether the cooler fan on the CPU along with the heat-sink are placed properly and attached to the respective connectors. Thanks, C Rahul.
Jul 04, 2011 | Computers & Internet
My computer shuts down after a few minutes
2 possible issues come to mind: 1) the computer is getting hot (CPU, memory or video card), 2) the power supply can't keep up with the demand.
Try using a program that lets your track your computer's internal temperature. System Information for Windows, http://www.gtopala.com/ , is the one I use. Depending on the cause, you may need to increase the ventilation of your case (add fans - slot cooler by the video card, front, back or side panel.). If the CPU is getting hot, make sure that the CPU cooler is working and consider removing it and reapplying a new layer of thermal paste before reattaching the cooler.
If the problem is the power supply, check the specs on your devices (memory, CPU, video card) and the power supply load rating. You may need to upgrade the power supply.
I hope this helps.
(I am not a gamer but the default power supply that came with my computer didn't have enough power for the added memory and video card. I replaced that and added a back fan (spot available), a slot cooler, a drive bay fan and cut a hole to add a side panel fan.)
May 08, 2010 | Biostar P4M900-M4 Motherboard
Comp. does'nt turn on. power is good
Your question fails to provide sufficient information.
.."doesn;t turn on power good...."
do any lights on the pc illuminate
was it working before, and did it close down correctly
has it possibly been hit by lightning
have you recently opened the case to install new hardware?
Possible causes of a failed power up.
dead power supply
a video card not seated in its slot correctly
dud motherboard
motherboard installed incorrectly
no Bios battery on motherboard
faulty wall switch
faulty power pack switch
no ram installed
and on and on
thanks for using FIXYA
Oct 10, 2009 | Intel Motherboard
I have a EMachine T6534 which won't start. I shut
I agree...sounds like a power supply problem. Typically a bad power supply will not damage the motherboard. It should still be functional.
Sep 02, 2009 | Computers & Internet
Finding a cpu cooler replacement for motherboard with screwholes.
You should be able to purchase a cooler that fits your existing cooler plate.
Replacing a cooler can sometimes be a lot of work. Sometimes you have to remove the motherboard from the case and remove the cooler plate from the underside of the motherboard. Then coolers that use "just the holes" can be used. Or another (different) cooler plate can be installed that may have came with your new cooler. In my experience, the coolers that use "just the holes" (no plate) leave a lot to be desired. Plus, if you're not careful, you can damage the motherboard by applying too much force when installing the fan. If you use a new plate, don't forget to install the insulator between the motherboard and the plate, if it comes with one.
Be careful to protect against unwanted electrostatic discharge. Always touch the metal computer case before touching any parts inside the computer. Also, if you remove the mobo, take careful note of where all the wires go before disassembly.
Feb 13, 2009 | Gateway 838GM (RB838GM) PC Desktop
Motherboard NO Boot
have you made sure that the new hard drive is set to the same settings that the old one was ie master or slave and that the ribbon is attached the same way
Aug 21, 2008 | ASUS P4S800-MX Motherboard
Motherboard is not booting!!!!!
Hi Jay,
Is you're memory installed in the two yellow slots?
Try using only 1 DIMM in DDRII_1 slot.
Page 17 in you're manual. When using only one PCI-E graphics cards you do not need to plug in extra power to the board, as shown on page 19. (Only need this additional 4-pin Molex when running two PCI-E cards).
Check internal connector is plugged in item,
1 ATX_12V_2X (Pg. 23 in you're manual).
(System will not boot without this).
Also item, 2 main power 24-pin Molex cable is securely connected. Chassis Intrusion Header (By default is opened/no jumper). I don't like the CPU getting hot. It shouldn't. Do you have a spare heat sink & fan for you're CPU? Are you 100% the cooling system is running correctly?
Lastly, here is Gigabyte's Qualified Vendors List (QVL), for you're board. Corsair 2GB is not listed.
http://www.gigabyte.com.tw/FileList/MemorySupport/motherboard_memory_ga-ma790fx-dq6.pdf
Luck!
Mike
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Hard disk problem
Do you mean the fan is running more loudly?
It's possible the additional heat from the hard drive is raising the temperature inside the case. Most fans are thermostatically controlled (they run more the hotter the PC is) so you'd expect this.
Will it affect the motherboard? If the the fan is running properly, no. The PC should shut itself down before thermal damage occurs. Make sure you don't have it tucked into a space where there's no airflow.
Make sure all the vents are clear (vacuum if necessary); I will even open the case and vacuum, but if you don't know what you're doing, I don't recommend this.
Dec 19, 2007 | Computers & Internet
D915GAG problem
this cant have anything to do with only replacing a cooler, unless when fitting it you have caused some sort of stress damage to the motherboard. Check all seatings of ram, graphics card and power connections in case they have been dislodged. I assume you have tried resetting the cmos settings in case there is a corrupt bios for some reason. The only other check is to see if the cooler is starting up straight away, as the processor may be shutting down if there is no fan running, or the motherboard is reading the temperatures incorrectly and not enabling you to boot.
May 09, 2007 | Intel D915GAG Motherboard
Computer powers off while booting, green light stays on!
1. check the cpu fan is properly working with normal speed..
2. go to bios setup and restore all settings to default.
3. if windows start and problem comes after some time , then it might be virus. so, go for a virus scan.
Oct 23, 2006 | Asrock K7VT4A+ Motherboard
ASUS P5PE-VM Motherboard Logo
42 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Tony
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
