Aircon unit not working samsung 9000 btus lights but not working
When you press remote all lights flash but unit does not work
  • ahibm Nov 12, 2008
    all the lights flash & the unit does not turn on or off
  • 4 Answers
Does it even turn on?
Like is the fan working/moving?
Posted on Sep 27, 2008
Samsung air conditioner energy icon is flashing and outside unit is not working
The flashing light indicated that the unit is not getting power. That, or that the power went out. If the power went out, it might just need to be reset. Otherwise, the controller might need batteries.
Elisa Jed ' http://www.karair.com.au/aircon-installations.htm
Aug 16, 2014 | Samsung Heating & Cooling
LG aircon operation light flashes 8 times and then shifts to timer light flashes 4times and then back again to operation light but aircon is not operating.
jz on the aircon manuly on inside the front door.lift the front on the indoor unit there the on/off button,jz press it.don't use remote it can help u
Apr 20, 2014 | LG Heating & Cooling
Panasonic inverter aircon R410 A goes to timer all the time
You have to use the remote in service mode to find the error code. Hold the 'check' button in with a paperclip for about 5 seconds and "--" will be displayed on the remote. Press timer up or down will change the error code displayed. When you hear the main unit start beeping quickly for about 4 seconds, that is your error.
Nov 03, 2017 | Panasonic Heating & Cooling
The screen on the remote is working however it doesn't seen to be make a connection to the unit therefore the aircon unit isn't turning on. How can we fix this?
This sounds strange but if you have a mobile phone with video recording on it, run the video whilst pressing the remote control. If you point the camera at the end of the remote (Where the glasslike bubble is), you should see it flash ( On the camera) You will not see anything with the naked eye, you must look at it through the camera while on video record. If you see a flashing, it means the remote is OK and you will need what is called " a receiver board" in the indoor unit of your aircon. If it doesnt flash, it means the remote is faulty. Try the manufacturer for a replacement .
Bye the way, any remote control can be tested in this way... try it with your TV remote to confirm it works..
Jun 16, 2011 | Heating & Cooling
Samsung aircon remote not working
Does your remote have batteries? If yes change them. Somewhere on the unit there should be a selector switch, put it into test and manually lower the thermostat setting
Feb 14, 2010 | Heating & Cooling
Remote does not turn on Panasonic CS-A28BKP5
Point the remote control IR LED at a digital camera such as your phone camera (The LED is usually on the top of the remote and is what is used to transmit a signal to the receiver board on the head unit). When you press any button on the remote, a purple flash from the LED should be seen on your camera screen. If not, you have a faulty remote. If you see one, you probably have a faulty receiver board and will need to replace it.
May 11, 2017 | Panasonic Heating & Cooling
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Timer green light flashing when turned on but aircon isn't workn
reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Jan 31, 2009 | Heating & Cooling
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
