Question about Nokia N73 Cellular Phone
SMS alert not working
When I receive a SMS i don't get any alerts.
No Vibration,no tone or no alert on the screen
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 147 Answers
Check the ff:
-You might have turned your "message alert" off or your phones "volume" off or silent.
-"Vibration" alert is off
Try this:
-Turn the "vibration" on or activate.
-Be sure the phone "volume" is not zero, empty or off.
Notify me if it doesn't work, if it did pls rate this solution...tnx
Posted on Sep 27, 2008
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
No message alert
I dont receive alert tone and vibration when i receive any sms?
Jan 20, 2011 | Nokia E52 Smartphone
How to change Message Alert tone
The msg alert tone depends on the current sound profile of your phone (like normal, silent, driving etc).
1. Go to main menu -> settings -> phone profiles. You should find all the profiles available in the phone. For example, we will change the msg alert tone for 'normal'.
2. Tap on the box with the double arrow (>>) symbol next to normal. You should enter a screen saying call alert type, voice call ringtone etc.
3. There is a drop down menu at the top right side of the screen. Tap that and select 'new messages'.
4. 'message alert type' should be melody or vibration & melody, depending on your preference.
5. now select 'message alert tone'. The phone has a number of tones already stored. Select one of these.
6. Or select 'sounds' at bottom right and browse to any file you want to set as message alert tone instead..
7. Save and exit !!
----pls rate if you find it useful-----
Jan 05, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Hi, How do I change the SMS alert to a tone on the Blacberry 8520? Thanks, Elaine
Hi there
Turn on your BlackBerry. Press the "Menu" key to go to the applications page, and scroll down to find the "Profiles" icon. Click the icon to enter the "Profiles" options menu.
Scroll down and click "Advanced."
Highlight the active profile and press the "Menu" key. Click "Edit."
Click "SMS Text." Change the field next to "Ring Tone" to your desired text tone. You can also change the volume and vibration option of the text message alerts from this screen. Press the "Menu" key when you are satisfied with your changes. Click "Save."
Oct 01, 2010 | RIM BlackBerry Curve 8520 Smartphone
How do I change SMS alert tone on Samsung Tocco Lite mobile
Go to Menu > Settings > Phone profiles > click the two arrows beside Normal (or whichever one you use) > go to the top of the screen and select New Messages > Choose Message Alert Tone > Sounds > choose the file.
Oct 13, 2009 | Cell Phones
Dont get SMS alert
Peter, go to menu-settings-personal-tones. Set a ring tone for message alert.
Aug 08, 2009 | Nokia N73 Cellular Phone
No message alert tone
You will need to access Profiles>(Whatever 'Profile' you have defaulted you will need to edit) Use your options button and access 'edit'.
There will be a list of all your features that you customize any sound for. When you seeing Messaging, access that feature and personalize your on alert.
Hope that helps! Thanks.
Mar 17, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Sms text tone
Make sure you change your message alert type to Melody or Melody and Vibration before you get to pick your text alert tones or songs. If I remember correctly, my phone was set to only "Vibration" when i first got it.
Dec 29, 2008 | Samsung U900 Soul Cellular Phone
No SMS Alert
check out details in ur profile in Tools....
Personalize ur present profile and check ur message alert tone is none or not....
Oct 01, 2008 | Nokia N70 Cellular Phone
Nokia N73 Cellular Phone Logo
328 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
