Question about Bulova Watch
Remove back of Ben Sherman Watch No.S762 to replace battery
Unable to find how to remove the back of my stainless steel (square) Ben Sherman Water Resistant watch to change the battery.
SOURCE: how do change a battery of a watch?
If you do not have the proper tools,(proper tools are recommended) and depending on the type of backing, this may help you :
  1. Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal.
  2. Get a kitchen knife with a rigid blade. It doesn't have to be razor sharp, it only needs to be inflexible. You can also use a small fine screwdriver.
  3. Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  4. Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  5. Locate your battery(Small round disc type) remove and check the numbers on it. Go to most any local dept. stores (Wal Mart, Target, Radio Shack, etc.) and purchase same.
  6. Install battery with numbers up.
  7. Place cover over watch, and snap back into place.
Hope this helps. If not, please let me know and I will get back to you.
Posted on Feb 07, 2008
  • 2334 Answers
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Posted on Dec 17, 2008
  • 51 Answers
SOURCE: Watch band sizing
OK, I make an attempt:
I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
You can push it out with a blunt sewing needle (break off the tip).
Remove links on both sides of the watch when resizing it.
Hope that helps.
Posted on Dec 27, 2008
SOURCE: How to Remove Watch Case to Replace Battery
the anser to the question is you need a special tool to open the watch as this is a screw back and you can buy this from Watch repair dealer from about £10
Posted on Feb 03, 2009
  • 2334 Answers
SOURCE: trying to shorten stainless steel watch strap
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 27, 2009
Is the fossil fs4813 waterproof
yes, to 50 metres
Fossil Men's FS4813 Grant Stainless Steel Watch with Leather Band ...
Rating: 4.5 - ‎50 reviews
Tang clasp. Water resistant at 50 meters / 165 feet. Casual watch style. Fossil Grant Chronograph Black Dial Brown Leather Mens Watch FS4813.
Grant Chronograph Brown Leather Watch - Fossil Rating: 4.6 - ‎91 reviews - ‎US$115.00 - ‎In stock
PRODUCT DETAILS. Collection: Grant. Movement Type: Quartz Chronograph. Case Size: 44mm. Strap Material: Genuine Leather. Water Resistant: 5 ATM ...
Water Resistant Watches, 10 ATM Watches ' FOSSIL******/10-atm-watch.html Water Resistant Watches up to 10 ATM. Fossil Hybrid Smartwatch - Q Nate Dark Brown Leather Ftw1114. Quick Look. Fossil Hybrid Smartwatch
Is the fossil fs4813 waterproof Google Search
Aug 16, 2017 | Fossil Watches
At size is the battery in a mens fossil blue watch
take to Walmart and have them put in a new one .
Feb 15, 2015 | Fossil Watch
Need correct replacement battery
the watch movement deters which battery the watch needs it is very important you do not put a battery in that doesn't suit the watch as it can short out the circuit however you can get the correct size in a gold seal quality which should not leak, also the older the watch, the more demanding the watch becomes on the battery as the movement components start to experience wear and tear
Apr 16, 2014 | Wenger Swiss Military Alpine Diver...
I have a wittnauer longlife 100 meter watch that always rolls the date at the wrong 12 hour interval. I change the date at 1201 am or 1201 pm and have tried to do all sorts of things to the same end. I...
Maybe this model is a self winder?
Bulova owns this brand. I suggest you check out this site:
Wittnauer and Bulova are better watches, usually sold at better jewlery stores. Perhaps you can get more information from a better jewler in your city.
Mar 03, 2010 | Watches
Please send step by step directions for replacing the battery, CR1216 in a Timex water resistant 30 M stainless steel women's watch. Are there special considerations for taking the back off because of the...
Most makers recommend that you take it to a watch shop. As you correctly suggest, the seal is important abd might be betterleft to the professionals.
Dec 27, 2009 | Timex 27191 Wristwatch
Can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Jan 05, 2009 | Croton Watches
Replacing the battery
i have a sinobi sports watch thats stainless steel, back water resistant model (2968g) and i just bought it, but the batteries died and i dont know how to replace them
Dec 07, 2007 | Timex Expedition T41261
Bulova Watch Logo
3,034 people viewed this question
Top Bulova Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
