Question about IBM Aptiva E 240 (2158240) PC Desktop
Computer Does not Boot correctly, Monitor is Black.
I've been trying to figure this one out for awhile now.
Ok here is the issue.
We are trying to get the computer to boot up, at least into Bios, but there is no Display(Monitor is black), Keyboard seems to have activity but unable to use(Numlock lock, cap lock etc does not work, but I Know that the motherboard knows It's there because when I unplug and plug the PC back in all three lights on the Keyboard flash once(The Numb Lock, Cap Lock and Scroll Lock lights).
Also, I Used a wireless Keyboard and the lights on it comes on, and every time I hit a key It's action light flashes(Which is normal). The Display does not come on at all, We tried the onboard video, A PCI-E Card and a PCI Card, nothing.
The DVD Drive seems to work, Hard Drive works, Mouse and Keyboard seems to work, at lease they get power, All fans work, all lights work, I Tried another monitor(same problem).
The Computer does one short beep. but that means nothing, I Took out the memory, unhooked the Harddrive and still it does one short beep.
I Resetted the bios by removing the Motherboard Jumper and placing it back on, I Tried a different battery, no Luck.
IT Doesn't seem like it's the motherboard, The only thing we can think of is not enough power?
We rechecked everything, everything seems ok.
Could a Bootup disk solve this Issue?
Thank you.
  • 1 more comment
  • waltercross Sep 27, 2008
    Ok I'll try to reinstall the OS, but I've stuck the CD in before and no Luck.
    Let me try again.
  • mschoaybq Nov 28, 2008
    Ya, I have exactly the same problem...
    Is there any solution to this?
    Does Dual boot is the problem, as I have 2 separate hard Drives out of which one has FC5 & other has XP.
    The system has been running very good, but ithas started happening yesterday.
    I had to install a Sangoma Card or Ambient MD 3200 card for some experiment.
    I first pushed the power button & just started to install it, I guess the system did not come to a total halt & meanwhile I tried to install the Card.
    There are so many server machines in that area that I couldn't hear the power supply fan's noise. I didn't notice the processor fan was moving or not that time...
    But now I guess it was spinning too...
    So techies!
    is this now a motherboard problem some short circuit or some thing else...
    Why can't I have video output & why the detected keyboard is not working...
    The DVD-Writer & optical mouse are getting power, The hard drives are vibrating, meaning getting power & spinning,....
    Whats the problem...????
  • antonygreat Jan 29, 2009
    my pc doesnt boot,it produces bootikng sound then only the cooler fun runs,mouse ,keyboard and monitor seem to be ok.how can i heal this problem
    Scholar:
  • 191 Answers
Try to reinstall the OS..if it doesn't work then there would be a problem with ur motherboard becaouseof failure of IC's. So contact the service men.
Posted on Sep 27, 2008
3 Suggested Answers
kim_cu
  • 70 Answers
SOURCE: Computer Does not Boot correctly, Monitor is Black.
Very interesting...Might try the following...
- Video. Yes, almost garuntee that it is either the video card/onboard or the cable. Look at the cable and cable connectors and see if one of the pins has been shoved in. This is common. Often, one will replace the cable and still have the problem because a pin has been shoved in on the mother board.
- Power. Remove everything from your computer except the keyboard and the monitor (yes, even the mouse) to eliminate any power drain issues. If you can, remove the DVD drive (unplug power and data bus cable).
- BIOS. One beep is good. You should be able to get into the BIOS setup no mater what other problems you are having. The BIOS uses a generic text, video and keyboard driver. If you aren't able to see ANYTHING after the beep then it is definately the route from the motherboard through the video card or onboard video, through the cable to the screen. You seem to be going through the right steps to debug but just haven't found it yet because it is something that you have dismissed as working...like the pins on the video connector. Go through your path again, this time look at anything that you have assumed that was working and suspect it as the issue.
Posted on Jan 08, 2009
  • 7 Answers
Hmm it seems to be problem with Power Supply, but still if you can give a try connecting your system into other socket may be which is properly grounded one.
if the above didn't fix your issue, i would suggest you to disassemble and then assemble it again. try changing the data cable as well..  Last option left is if you have a spare SMTP checkout with that.
Let me know if it works..!!
Posted on Mar 13, 2009
Asus crosshair socket am2 motherboard not booting
Sounds like your monitor is bad. Try another monitor because if the video card was bad and the monitor is working you would get a No Signal message on the screen. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not display anything, then there is an issue with your video card.
May 13, 2012 | Computers & Internet
Black screen just after boot window from USB
Sounds like either the monitor or video card inside the computer is bad. Try connecting another monitor to the computer. Borrow a monitor from a friend, neighbor, relative or co-worker and plug it into the computer. If the borrowed monitor displays ok, then your original monitor is bad. If the borrowed monitor does the same thing and not show a display then your video card inside the computer is bad.
May 09, 2012 | Computers & Internet
Hanns-G HW191D Monitor - Gives black screen with "No Signal Input" error message. Ever since I hooked this monitor up with my new system, it will randomly freeze (for a brief moment) and give...
You have computer problem, you can easily verify by using this monitor with another PC or another monitor with this PC.
It may be video card driver problem, since the PC was not properly shutdown, it will give you that message "boot in safe mode or normally".
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 17, 2011 | Hannspree HW191D LCD Monitor
My Samsung SyncMaster 913V (Black) 19 in. Flat Panel LCD Monitor, does not work correctly. Every time I reboot my computer the screen only works for a few seconds and after that it gets black and a...
Resolution setting of computer is not compatible with spec on monitor. Adjust computer res setting to agree with monitor and you will be good to go. If settings are ok then the issue lies within the innards of your monitor.
Apr 15, 2017 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
Monitor comes on momentarily then black...tried 2nd monitor same
I suggest you try another video card in your computer. This may be the culprit if the second monitor did the same thing as the first. If the different video card does the same thing, I would then suspect the motherboard.
May 31, 2009 | Samsung SyncMaster 931BF LCD Monitor
Mar 13, 2009 | Computers & Internet
Jan 08, 2009 | Computers & Internet
Monitor turns black and with a not optimum mode pop-up
Press F8 when you boot your PC, Then boot on SAFE Mode...
Right Click on Desktop>>Properties>>>Settings>>>Advance>>>Check the Apply the New Setting without restarting.
Click Apply then OK
Rebbot the computer to a Normal Boot
Oct 09, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Black Screen after sitting for awhile
Might be that the graphics card is overheating.
Nov 08, 2007 | Acer Aspire 5100 Notebook
IBM Aptiva E 240 (2158240) PC Desktop Logo
480 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
