Question about Hotpoint Washing Machines
Hotpoint bearing replacement
So far I have stripped down my washing machine, which is a Hotpoint WMA22 model. My problem at the moment is how to remove the inner drum from the rear half of the outer drum where the bearings are. Hope someone can help. Regards Ray
  • Anonymous Mar 14, 2014
    is it possible to renew drum bearings from the aquarius wml540 model
    Genius:
  • 1,028 Answers
Remove rear pulley and pull like crazy ..usually have to change rear shell bearing and seal are pressed in be sure to ck spindle on basket for scoring before reassembly if scored replace basket
Posted on Sep 27, 2008
Our hotpoint wma22 does not fill as cloths come out dry. How can we fix this
check ur water hose line from the home, the water inlet valve itself , and the water pressure switch
Jul 10, 2014 | Hotpoint First Edition WMA22 Front Load...
Hotpoint wma22 not draining water properly
Take the hose of the back clean and blow through.check filter.Allso check bushes on motor
Aug 16, 2012 | Hotpoint First Edition WMA22 Front Load...
I have a hotpoint wma22. problem with it does not spin.The belt is ok .
+I would remove the motor and check the brushes for wear.
If they are less than 3 or 4mm long, thet need replacing.
If brushes o/k, then it is probably a control module fault.
I am of course assuming that the washer has drained the water out, or it will not spin.
Jan 12, 2010 | Hotpoint First Edition WMA22 Front Load...
Wma22 does not spin
Could be a blocked pump filter, or worn brushes in the motor.
Check the flkter first, if that is o/k, then remove the motor and check the brushes., if less than 3 or 4mm long, then replace them.
Jan 01, 2010 | Hotpoint First Edition WMA22 Front Load...
Our hotpoint WMA22 washer will fill with water and wash but will not drain.i have lowered the drain hose to almost ground level and it will empty the water, and then will spin. In your opinion is it the...
Sounds like a blocked filter to me.
Remove lower rear panel of washer, remove large black hose fastened to bottom of drum, remove and clean filter inside hose, check pump for blockage at same time. You probably will not need to replace any parts
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint First Edition WMA22 Front Load...
Hello there, I am trying to source a drum bearing for a Hotpoint WMA22 washing machine. Is a WMA22P bearing suitable? Only I have found two sizes advertised for a WMA22P (30 & 35 mm) Thanks, Clive.
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our sitehttp://www.apart4u.co.uk
This first video shows you how to diagnose the problem
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Oct 05, 2009 | Hotpoint First Edition WMA22 Front Load...
Hotpoint wma22 is leaking between seal and door
It could be an over filling issue, or there may be a tear in the seal where you can't see it very well Take a look at my articles:
http://www.fixya.com/support/t1667828-water_spewing_out_air_vent_back_washer
Which discusses pressure switches, or
http://www.fixya.com/support/t1543617-door_seal
if you discover you do need to replace the door seal
Mar 01, 2009 | Hotpoint First Edition WMA22 Front Load...
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
WMA22- Machine has started making lot of noise.
Sounds lika main drum bearing problem
As it is only 6 months old, then you should contact service agent.as it will still be under guarantee.
Aug 02, 2008 | Hotpoint First Edition WMA22 Front Load...
Washing Machines Logo
324 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
