Question about Gateway 7330GZ Notebook
Importance of hard drive partial metal enclosure.
If a newer hard drive won't fit snugly in the partial metal enclosure that should fit in the plastic holder and guide, can it be discarded without any impact to the drive? What purpose does the partial metal cover serve?
  • Alrick Elliott
    Alrick Elliott Sep 27, 2008
    Thanks for your knowledge and for being there.
    Brigadier General:
  • 6,966 Answers
To my knowledge, the purposes are:
  • spacer, since not all harddrives have exactly identical dimensions and replacement may differ. The manufacturers of the laptop to ensure that all would fit makes the space big enough for the biggest and insert spacer to compensate with the slightly smaller models;
  • heat shield, as the name implies puts a stop gap between the physical closeness of two heat sources so as not to contribute to the temp of the other, hard disk and motherboard/casing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 27, 2008
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
How to ground a Tork EW103B time switch wired for 240Volt since there is no ground lug in the plastic housing or on the body of the timer itself
Many plastic timer enclosures do not have ground screw.
Simply join the ground wires inside wiring space using wire nut.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#ew
Since the timer mechanism is plastic, it is non-conductive.
It's like using all-plastic electric drill. The drill does not have ground wire because the electrical components are housed completely in non-conductive plastic.
You can buy the Tork 9000A metal Nema3R enclosure if grounding is preferred. Or buy Intermatic 2T511GA metal Nema3R enclosure plus buy Tork IAP adapter to fit Intermatic enclosures.
Choose the metal enclosures when conduit needs to be supported and timer could be hit by some object.
The non-grounded box and non-grounded timer is also true of GE digital timers 15132 and 15136. Which coincidentally have same wiring as EW103 when using 240Volt.
http://waterheatertimer.org/How-to-wire-GE-15132-timer.html
However the Tork DTU40 timer has ground screw >>> but the timer is not grounded, so ground screw is merely for joining wires together.
http://waterheatertimer.org/images/IMG_2232-Tork-DTU-timer-600.jpg
Jul 31, 2012 | TORK Hardware & Accessories
My simpletech simpledrive 1tb stopped working and wasnt being recognized by my computer, i talked to a tech person on the phone and they said the controller stopped working. told me i had to take it...
If you are suppose to send it to the manufacturer to get it fixed, opening it will generally void the warrenty.
If the hard drive enclosure is bad you can buy a new enclosure for around $6-$15 online. Buy the right enclosure either a 2.5" or 3.5" just measure the shorter side and it shoukd be close inside to the drive. Open the old case slide the drive out and into the new enclosure and your done
Alternately if you want to just back it up and try and sendd it in to get fixed. --Open the enclosure and slide the drive out. (This only works with a desktop) for hooking it up to a laptop use will need a sata to usb adapter. Remove the side panel on a fairly new computer 3-4 years old or newer (you will need a extra sata data cable) plug into the drive into an open sata port in the desktop and connect the power. Turn on the desktop and it should discover the new drive.
D
Aug 03, 2011 | SimpleTech 1TB External USB 2.0 Hard Drive...
My Metal Gear Box external hard drive has a flashing blue light, and my computer does not detect the external hard drive, what is the problem?
the weird cheap power supply they used has failed. I will never buy another galaxy product. This whole time I thought the hard drive crashed, but it was the enclosure all along that died at about a year.
Nov 14, 2010 | Galaxy External Enclosure - Metal Gear Box...
I have a inspirion 6000 it says cant find hard
You may have a bios setting to check, it also may be damage on the connector or on the actual south bridge from over heating. I would load up into the bios and see if your drive is being detected and has the proper settings, try a default bios setting and see if that helps.
Aug 01, 2010 | Dell Latitude D600 Notebook
Lost pictures
Depending on the exact failure, you have a couple of options. A friend of mine had a similar drive with important photos an it turned out the drive itself was OK, the enclosure had failed. I removed the drive from the enclosure, and connected it to another system with a drive adapter, and recovered the data.
If the actual HDD in the enclosure failed, you can contact a data recovery company like www.drivesavers.com and get an estimate on data recovery (Generally very expensive, just depends on the importance of the data)
May 25, 2010 | Western Digital WD Passport 250GB Portable...
External hard drive fell off table now ''drive not found''
these drives are a bit delicate and do tend to damage easily when dropped. You may just have knocked a cable loose, could have damaged the usb controller board or may have damaged the HDD.
If you're not concerned about warranty, you can slide the shell off of the body of the drive with a little prying around the back edge(around the metal end with all the plugs. It can be put back when you're done but you will likely leave some tool marks on it.
Once you have it open you will see the HDD mounted along the cases length, at one end it has two small cables attached. ensure they are snug, then follow each to it's other end and ensure they are snug, the check the small circuit board running perpendicular to the HDD to ensute the pinned end it securely attached to the larger ciruit board.
Test the drive, if no luck the next step involves buying a new drive enclosure. Go to you local computer store and ask for a 3.5" SATA Hard Drive enclosure. Then finish disassembling the Western Digital, removing the HDD and placing it in the new Enclosure, be careful not to touch the circuit board attached to the bottom of the hard drive.
Once you've installed the HDD in the new enclosure plug it into your computer and power it up. If this works your done, if not the HDD may be finished.
Still if this doesn't work you can send the HDD for recovery to a pro, try Armor-IT Data Recovery in Canada, they have good rates and are listed on FixYa's directory.
Hope this helps FixYa
Chris
May 10, 2009 | Western Digital 250GB MyBook External USB...
Open hard drive enclosure
(I found your question because I had the same question. Decided to go for it.) The aluminum top and bottom covers are held in place by the indentations on the sides which fit into channels on the plastic chassis inside. I used a flat knife blade to gently pry by the front end of one side until the cover moved moved slightly out of the channels, then switched to the other side. Once I had it started, I was able to just lever the cover off by grasping the front corners and swinging it up in the reverse motion of the installation procedure. Caution: Prying too hard or far at once will bend the covers and or nick the plastic chassis extrusion. Good luck
Dec 10, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
I-rocks ir-9200
when u want to use them them in an encrosure u first have 2 remove the metal bars that attach the hard drive to the laptop once the bars r removed it iz ready to fit in the encrosure
Apr 22, 2008 | i-rocks External Hard Drive Enclosure -...
Gateway 7330GZ Notebook Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
