Can't load profile is a common error. It means your profile is corrupt. You can try logging in under a different profile, if that let's you in you can run System Restore. If there is no 2nd profile to load to, it's time to reload the OS.
go into control panel and create a new user (dont make it the same name as your old profile) then restart the pc and log into that new profile. To retrieve all your settings favourites etc you will need to say what version of windows you are using
ok this is what you to do restart your pc then after you restart your laptop press f8 then goto safemode and select admistrator you can find there run you can type there restore
What I would suggest is logging on in safe mode and trying to restore it to an earlier date using system restore. likely the profile is corrupted. By doing a restore back about 4 to 7 days , or before this started happening, will likely fix your issue. If not you will have to purchase the restore cd from toshiba or restoring it from a recovery partition if it has one.
Hi deardo one thing ..restart your laptop …. PresF8and go to safe mood restore old date when your date work normally without any problem (Exp: 5 days or one week before like that)
Thank you
Imran
Pls give you me a rank as possible
This sounds like an operating system glitch. Enter safe mode at start up by pressing F8. Once in safe mode, log on as administrator and do a system restore to a point that you recall it allowing you to log onto your profile. This should cure it, if not, let me know and we'll try something else.
