Question about Motorola Mobility RAZR V3
Keypad acting up!
I have a Motorola RAZR V3, and for some reason, the keypad doesn't work. When the phone is off, and I press the red "End" button, it turns on the phone, and that should mean that it works.. But when the phone is on and to the main screen, none of the buttons work. I press all the buttons and for some reason it goes to the Camera frequently.. Any solutions?
  • 1 more comment
  • vgetson Sep 27, 2008
    I have had this phone replaced already (under warranty) for the same reason and now it is doing it again. All of a sudden the keypad freezes, I can only turn it on or off -- no other key works. I have taken out the battery, left it off all night, turned it on and off several times -- nothing works... Apparently a common problem in this model of razr...
  • Brenna_judd Sep 27, 2008
    My keypad doesn't work but I can turn my phone on and off. Then my camera turns on and off but none of the other buttons work.
  • SurgicalBomb Oct 11, 2008
    I found a better solution. I got pissed off and gave up with the phone and just didn't bother it and then it ended up working the next day. :)
    Brigadier General:
  • 7,752 Answers
SURGICAL - you need to replaced the mobile flexcable in the phone also have the repair center flash the keypad flexfile back into the phone.
BRENNA - replaced the flexcable
VGETSON - you need to flash a file call keypad flex into the phone to correct the keypad freezing up on you.
Posted on Oct 05, 2008
Only One Button Works On My Motorola Razar
fone may need flashing or keypad changed
Aug 31, 2009 | Motorola Mobility RAZR V3
Motorola v3 problem
looks like you need a clean of the unit and replace the keypad.
refer to here for intructions
http://thydzik.com/motorola-razr-v3-repair-and-housing-change-guide/
Jul 21, 2009 | Motorola Mobility RAZR V3
Razr keypad
its a simple problem and i dnt tink u will b able to do it.the main bord is connected 2 da key pad wichs also conects to da lcd.so basicly ur ribon is damaged.it cost about 150rand to repair.
Jul 28, 2008 | Motorola Mobility RAZR V3
Only the power button works on my razr keypad, help
replaced the flexcable on the phone.
take the phone and have the phone flexcable replaced
Jun 07, 2008 | Motorola Mobility RAZR V3
Frozen keypad
How long have you had your phone?After a good amount of time the razor starts to act up and then all togther it will die.
Mar 21, 2008 | Motorola Mobility RAZR V3
Motorola razr freezing
your phone problem is the keypad flex of your phone'
you can fix it by replacing the keypad flex'
motorola dealer has the keypad flex'
ask for a skilled cellular technician to re-place your keypad fle..
i hope it will helf to your prob...
Jan 07, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 keypad....!!!
This is usually caused by one button being stuck down, and the volume control buttons on the left of the main display, and the voice button on the right of the main display are the usual culprits. Try squeezing them and making sure they move normally. Then power down the phone, pop out the battery, and give it another shot.
Dec 15, 2007 | Motorola Mobility RAZR V3
Motorola razr v3 keypad problem!!
Press all of the buttons and keys on the phone one by one with it powered off and the battery out. Make sure they all feel normal to the touch and when pressed. Check the buttons on either side of the main display carefully, as these tend to get stuck more than others.
Keypad will not work
This happened to mine after I got the Razor wet - I pulled the battery and the sim card, blew it out with a can of compressed air and it worked for about 8 months. Then it got hot out in my car and started doing the same thing - blowing it out hasnt worked again-
Jan 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
145 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
