TV Parts Universal TV Stands DLP Chips ShopJimmy They should have the IR board for your Sony TV.
SOURCE: Need Universal remote code for Magnavox 15MF400T/37
these are the codes associated with Radio Shack's line of remotes:
One for All Universal (Radio Shack)
0054, 0179, 0030, 0020, 0024, 0096, 0186, 0171
And I was also able to find these:
UNIVERSAL REMOTE CONTROL CODE LIST for TVs
MAGNAVOX
002 009 109 118 209 309 402 408 502 508 510 807 914 917
SOURCE: The TV stopped receiving IR signals from remotes
make sure that your remote has a line of sight to the tv. often a small antenna is added to enhance reception. also check to be sure your remote batteries are aok.
SOURCE: Remote sensor on TV (LG 42PM1MA) seems to be broken.
Have the technician check for 5 volts on the remote IR Sensor if present the the Remote sensor has failed. Have him replace it to factory Spec's. No need to replace entire main board when the sensor is no more 5 dollars....
Testimonial: "Thanks a lot. Seems you've done this yourself :)"
SOURCE: My Sony Bravia KDL-40D3000 no longer responds to
Remote sensor seems bad in your KDL-40D3000 that will be replaced because it is unable to receive remote infra red signals and remote has been tested on other tv and found good.
Please replace remote sensor in tv to get it fixed, local tech will help you to solve this problem.
Thanks.
