Porblem in webcam setup and usb mouse
I am having two problems regrading my notebook.
After reinstalling XP,and other drivers
I am not able to get my webcam working
another problem is i normally use usb mouse.
now after reinstalling usb mouse is not getting
So how can i solve this
  • 158 Answers
There was a problem in your usb of motherboard check it and give me detail
Posted on Sep 27, 2008
I have a Microsoft Wireless Notebook Optical Mouse 3000 which was working yesterday but is now not responding. The red LED on the bottom of the mouse is flashing, but the green LED on the USB receiver only...
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 01, 2011 | Microsoft Wireless Notebook Optical Mouse...
My microsoft wireless notebook optical mouse 3000 has stopped working. The battery is new, I tested it in a different laptop and it works fine there. When I plug in the usb, the green light does not go on...
try plugging it into another usb oirt if it dosent solve the porblem try to update the driver for it.
start>rite-click my computer>manage> device manager> find ur mouse (should have a "!"symbal next to it) right-click> update driver...
Dec 17, 2009 | Microsoft Wireless Notebook Optical Mouse...
Acer Aspire 3000 model was working great then the mouse froze tired of messing with it reinstalled os xp tried fn-f7 nothing now when your reinstalling os it works fine i would download drivers but I can't...
never let a machine defeat you
you did not say if it is PS 2 or USB mouse?
if PS2 go to MY COMPUTER, PROPERTIES,HARDWARE< DEVICE MGR, scroll down to MOUSE, then PROPERTIES, UNCHECK the box FAST INITIALIZATION
REBOOT. PS 2 mouse should work.
if USB mouse, scroll down to USB ports to see if there are any YELLOW check boxes under USB
this means no device is loaded and USB mouse (or anything else you insert) will not work.
click uninstall, SCAN, and let it reinstall.
try another mouse... hope you get cheese!
Apr 26, 2009 | Acer Aspire 3000 Notebook
Webcam causing windows to shut down
I think this a problem with a USB driver. I had a similar problem once with a USB mouse and keyboard, when running XP. I never isolated the reasons for it happening, but I uninstalled the USB drivers for both and reinstalled them and rebooted and the problem disappeared.
Maybe try uninstalling the Logitech driver and then doing a Registry Clean (and a Clean System) with nCleaner and then downloading the latest zipfile for your webcam model from the Logitech support webpage.
Then plug the webcam in. It will detect and try to look for drivers but not be able to find any.
Now unzip the driver to a folder. Go to Control panel > System > Device Manager, and look for the Unknown Device with a yellow exclamation mark next to it. Double click it to open the driver window and then click the Driver tab. Press Install Driver and choose the 'Browse Computer for Driver' type option and navigate to the folder you unzipped the driver to, select it and open it.
It will Install and then you should reboot.
The problem should be solved, unless some IRQ conflict still happens, in which case you should do a Scan for Errors with an operating system disk.
SO, to sum up, when in doubt, uninstall the driver, clean the registry,reinstall the latest driver, reboot!
Hope that helps
Chris (ziraffa)
Jan 11, 2009 | Logitech QuickCam for Notebooks Pro...
Logitech QuickCam1150 Notebook Deluxe camera not configured properly in xp error
Hi, Please uninstall any logitech software version present on your OS (if available) - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Nov 10, 2008 | Logitech Webcam
USB devices (not recognized)
Hi Hanna,
You may try to uninstall and reinstall the driver of your webcam. You may need to check also if the driver application is compatible with the operating you are using. Most of the new system we have now are operating in 2.0 USB port drivers.
If your webcam driver is compatible only with windows XP, then it won't help you resolve the problem if your system is operating in Windows Vista (new operating system for most new system).
Please clarify also the type and model of the webcam you are using. keep me posted.
Thanks.
Oct 11, 2008 | HP Compaq nx6110 Notebook
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
Wireless mouse
With USB wireless mice, you plug in the USB wireless adapter, and turn on the mouse. Windows XP should automatically install the software, if not, install the software on the disk that the mouse came with (if there is one). If there isn't a disk, Windows XP will most likely install the drivers automatically. Press the connect button on both the mouse, and the USB adapter, and it should all work. Good Luck
Aug 16, 2007 | Microsoft Wireless Notebook Optical Mouse...
Acer notebook 3002
I would try plugging an external keyboard or mouse in to see if that works. If it does, either the keyboard/mouse (2 in 1 on laptops) drivers are invalid in which case you can go to http://support.acer.com and download the keyboard/mouse drivers and/or utility. Otherwise, most likely the keyboard/mouse hardware is the porblem. In which case either the cable connecting it to the rest of the laptop is loose or more likely the entire keyboard/mouse device is fried. I suggest contacting the manufacturer (Acer) and if your laptop is still under warranty get them to replace it; if not buy it. -The Tech Guy
Apr 13, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
