Question about Sony Playstation 3 (PS3) Console
New play tv wont work via remote play on my psp
Hi, i have recently bought the play tv add on for my ps3,i have got the remote play setting to work allowing me to view the ps3 on my psp, the trouble is when i click to watch play tv i wait bout 25secs and get the message connection error has occured (8001006f). everything else works ok ie play music, see my pictures and even play my old ps1 game. can you help please.
  • 4 more comments
  • andymcrue Sep 27, 2008
    it dosent enable me to watch the play tv on the psp which is what it is intented to do, when i try to reconnect to the ps3 i have to switch the ps3 off to re-start it the reconnect to remote play.
    still no good
    its not the remote play that dosent work(this works fine) just the watching play tv on the psp (via the remote play)
  • andymcrue Sep 28, 2008
    already got the latest update. could i do with a better more powerful router?
    psp model is the new slim & light model psp-2003
  • andymcrue Oct 08, 2008
    my ps3 is only connected via wifi
    Genius:
  • 1,011 Answers
Sir,
Click this link for more information....
http://www.gamespot.com/ps3/action/lair/show_msgs.php?topic_id=m-1-42621773&pid=929230
thanks
good luck
Posted on Oct 09, 2008
  • 4,889 Answers
After registering the PSP to the PS3 , tick the box on the left of the `registered` psp. Its actually more easier than it looks..
Posted on Oct 08, 2008
    Sergeant:
    Champion:
  • 334 Answers
Yes i would say roughter is it that new linksysy black one then yes get difffernt one long ranndge netgear ect those faster longer fo tv mode make sure all settings are ready for that also 640 res make sure cable works should be like hdtv built ibnside tuner then just scan for what it can pick up
  • 1,879 Answers
To make Play TV on the PSP via the Remote Play work
watch the instructional video here
and detailed information here in full-color
be aware that this whole thing depends on the firmware version of both PSP and PS3
Posted on Oct 05, 2008
    Master:
  • 763 Answers
Try to see the connection cable and see if it has loosing or not properly connected with each other. you may check the manual of your psp for compatiblities of connections. see also the settings of your psp for the connection, maybe it has a configuration for it. hope that helps sir!
CHARCOIS
Posted on Sep 30, 2008
  • Sony Master
  • 6,487 Answers
Try first to turn off the psp and pas3 for 1 minute then power them back on and check if that will do any help if still the same problem, can you please mention as also what is your router , because sometimes this can be a problem with the router specially those all routers that some device will be having some conenction or data transfer between each other....
Hope that helps......
    Master:
  • 726 Answers
Did u do any updates ? u will need to do that
Posted on Sep 29, 2008
  • 171 Answers
Check the box for Remote Start via internet in the Remote Play Settings (It appears if you turn Remote Start On or Off then On).
  • 3 more comments
  • Todd Gale
    Todd Gale Sep 29, 2008
    Also, Make sure remote computer is not shut, down or entering standby. Also, go to the device manager and on the network card, make sure the option to allow this device to shutdown to conserve power is not checked. You are losing connectivity to the remote computer is all and this is related one of the two above things.
  • Todd Gale
    For egt last post, my bad
    You will need to set up port forwarding on your router. The port you need to open is UDP 9293. Connections on this port need to be forwarded to the IP address of your PS3.
  • Todd Gale
    ive done a bit or research on the error code you provided and this is what i found:
    Communication with the server failed.
    Error Code : (8001006F)
    - You are not allowed to access this server since its private.
    - You cannot access the server since its still "offline" (This is a Killzone.com Online problem)
  • Todd Gale
    Register the PSP to the PS3 , tick the box on the left of the `registered` psp .
  • Todd Gale
    ''Yeah, it works like this. Basically you need to configure both the PS3 [which in this case is going to be the 'access point'] and the PSP, forget about the router. Make sure ATRAC is enabled on the PS3 and then go to network settings > remote play connection settings. When you're prompted to, enter anything you want in the SSID field, say 'remote play', then as encryption it'll only let you select WPA-PSK (AES), so choose that, and then you'll need the WPA key, enter any 8 numbers you want.
    For address settings, you can just use the easy/automatic option, then just press X to save the changes, back to the XMB, go to network > remote play and select it. Now go to network settings on the PSP, infrastructure mode, then new connection [or just edit current one, doesnt matter], let the PSP scan for a connection and you should be able to select the one you created on the PS3, if you named it 'remote play' then it'll be there and show the signal strength. Hit X and then again select WPA-PSK (AES) as encryption and enter the WPA key you created on your PS3, you can once again go with easy/automatic address settings and then save the changes.
    Once this is done, they both have the same settings. On the PSP just go to network > remote play, you should be able to see PS3's XMB, thats it. Figured it out on day one after a little while, the online instructions sony provided arent really self explanatory unfortunately, try it out and see what happens. This does need to be clarified.
    Genius:
  • 1,268 Answers
Try to delete first the peer-to-peer connection or the Pairing connection between your PS3 and the PSP.
- Disconnect the PS3 from your wireless network
- Then disconnect the PSP from wireless as well.
- Let the PSP connect first to the wireless network (Infrastructure Mode). Make sure it can go online online when connected to the wireless network
- Now, let your PS3 connect to the wireless network as well (Infrastructure Mode). Or if you can connect the PS3 hardwired to your router that's good. Its recommended that your PS3 is hardwired to your router first to isolate the problem.
- If both can go online connected to the same network, try to click to watch play tv and see if that works.
Note: Just make sure your PSP and PS3 don't have any pairing or peer-to-peer connection directly to each other. Both must connect to your wireless router.
Posted on Sep 28, 2008
    Genius:
  • 3,422 Answers
HI,
You need to forward TCP and UDP on port 9293. When connected locally to the router port forwarding is not needed as the ports (if you could see them) sit at the edge of the router where the internet connects. Connecting the PSP to the router means you bypass the ports.
  • Priya darshan Sep 28, 2008
    Also please let me know the make and model no. of your router so that i can tell you how to port forward.
    Genius:
  • 1,447 Answers
Hi-
You need to update the software, there is a incompatibility issue thats why you cant connect. call you product vendor for this issue.
Hope his helps
Posted on Sep 27, 2008
  • Sony Master
  • 19,396 Answers
8001006f is network connection error.
This error means the psp cannot access the network.
Check first the cable and the connectors, if you have a replacement cable to test the connection, try it out.
Update your PS3, sometimes old firmware version do not work on some network.
Check all the network settings, both on PSP and PS3, if you do not set up the network, you also get error 8001006f.
Error 8001006f is also often related to problem with the Internet connection.
Check the box for Remote Start via internet in the Remote Play Settings, you get to this setting if you turn Remote Start On or Off then On, try playing with the setting.
If you use Internet connection, on the router try disabling the firewall for a while.
If you do not have Internet connection, that may be the reason why you get 8001006f.
If it still does not work, test the network connection on a different router, or on a different PS3, the cable or the software controlling psp connection may be defective.
    Genius:
  • 1,550 Answers
The error code indicates it is a communication error
Have a try to fix your problem
  • Put PS3 in a DMZ
  • Port forward all the necessary ports (believe me i have them all there)
  • Disable all firewalls
  • Re-register the PSP to the PS3
  • Update ALL FIRMWARE
  • Change the communication settings on psp to highest performance (lowest quality)
  • Enable remote startup via internet in the remote play settings on PS3
  • Leave ps3 in remote play standby mode
  • Made sure PS3 NAT is type
Thanks for using Fixya
SAM ANDERSON
    Sergeant:
  • 208 Answers
The error code
8001006f- Remote Play connection error. No PS3 signal over your network.
To know about more error codes visit www.se7ensins.com/forums/psp-help/88780-known-psp-error-codes.html
Double check these things:
1) Make sure your PSP is displayed on your "Registered Device List" on the PS3.
2) Make sure your "Remote Start" is enabled in your PS3 options.
3) Make sure you are attempting to connect by selecting the internet access point and not your PS3 (go into "Remote Play" on your PSP and choose the wireless access point, not your PS3- it will automatically connect to the PS3 it's registered with).
4)Also when you connect you have to press HOME>SETTINGS>Communication Settings and change it to Type 4.
Hope my info fix your problem,
Thanx for using fixya,
Waiting for your comments......
  • Swaminathan R
    Swaminathan R Sep 27, 2008
    May be you need to check with the TV connections,may be thats not responding.....
    Genius:
  • 1,142 Answers
So its just the connection error you get and apart from this you have no issues correct ?
I bought an opticall cable to play my ps3 threw my philips mx 3800d surround sound system but it dose nothing why wont it work please help
You have to set your audio out settings, since your PS3 is probably connected via HDMI and both video and audio passes through it you will need to select your audio source through the PS3 audio output settings and set it to optical out, here is a guide you can follow: http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
Regards,
Oliver.M
Jan 30, 2011 | Video Game Consoles & Games
Some games wont play on my ps3
Hmmm...are you using the latest firmware?
You could always call Sony for a direct answer @ 1-800-345-SONY
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
Ps3 freezing,not reading new discs
Hi!
First of all, try playing all of your games and see if its just one disk or your ps3, following that I would say you put in a blu-ray movie and check if that works. If it doesn't, get a USB memory stick and save all your important data. After that, reset your system settings.
You can do that by:
Settings> System Settings> Restore System Settings
After that try it and if it doesn't work, go again to system settings but this time around, go to restore ps3 system.
You can do that by:
Settings> Sysem Settings> Restore PS3 System.
It should be noted that all of your stuff will be deleted, so I hope you saved all of your game saves on that usb flash disk.
If it doesnt work then do the following:
call sony:
SCEA Consumer Services
1-800-345-SONY (7669)
Monday - Saturday 6:00 AM - 8:00 PM PST
Sunday 7:00 - AM 6:30 PM PST
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
Nothing appearing on the screen
you need a scart box the one that you put the yellow red white plugs in to then you put it in the back of the TV than go to av on the TV remote that normally works on new and old TVs
Jan 03, 2008 | Sony Playstation 3 (PS3) Console
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
PSP won't play any games
the reason the umd wont load is because someone shut the psp off when the game was loading. so whoever did that just messed up your psp. i know cause someone did it to mine now i have to get it fixed or buy a new one. and to get the psp fixed its not guna be cheap.
Dec 25, 2007 | Sony PlayStation Portable (PSP) Console
Hi def
add a scart connection , and use this to check that the hdmi setup is correct using the system settings option
Aug 09, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
219 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
