Question about AEG Washing Machines
AEG Lavamat W1010 Front Load Washer Half way through the cycle the machine trips the power in my apartment, sometimes it will continue if I manually move the dial cycle through. Now it won't even do that and its stuck mid cycl, whenever I turn it on the power trips
5 Suggested Answers
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Posted on Jun 12, 2009
  • 174 Answers
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Posted on Jul 24, 2010
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
Jan 25, 2010 | AEG Lavamat 72640 Front Load Washer
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 1000
hi
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat W1450 2 years old,
possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Oct 24, 2007 | AEG Lavamat W1450 Front Load Washer
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
May 18, 2007 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
102 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
