Question about Plumbing
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
September 25, 2008
Dear Fellow Technicians, I hope you can help me;
I have a Sears 4 Ton Hydraulic Automotive Floor Jack Model #214.12310 that I have owned for approx. 20 years now. It has been a real work horse I use it almost every week when I work on my vehicles.
The problem started around a week ago when I noticed that the jack would not lift past approx. 6" and then it would just oscillate up and down in short bursts when you would pump the handle or the foot pad. I checked the oil level and added a little bit, and then following the 3 page instruction manual that came with the jack I pumped the handle with the release valve open to bleed out any air in the power unit. However, this did not work, and the jack failed to lift as before.
I contacted Sears and learned that they no longer sell replacement parts for this jack nor could they direct me to a technical service manual that would instruct me on how to diagnose what the problem with the jack could be.
I have gone on the internet and I have tried to research this information but have only found repair shops that supposedly will service Hydraulic Jacks, but have not been able to find any book or literture on repairing them yourself.
If you have any idea what could be wrong with this Hydraulic Jack or if you know of a website that may have the information that I am searching for please respond.
Any help is deeply appreciated.
Thank You,
Eduardo A. Mosquera - Lennoxspaceneedle
  • 3 more comments
  • EdsHonda1987 Sep 27, 2008
    Dear Chris07551;
    If you could send me via E-Mail the diagram of how to do this it would be very helpfull.... I figured it was some type of seal or O-Ring that the pump uses to build up hydraulic pressure that maybe is leaking.... But without a parts disassembly diagram of the pump it is just guessing, and not fixing......
    You would think that Sears since they do not sell the replacement parts anymore would at least provide a diagram of the pump to make it easier to fix, but they unfortunately have adopted the "throw out and buy a new one" attitude that is so common with US company's today. I read online that Sears probably did not make the jack they just put their name on it, and I could not find anywhere on the tool the name of an independent manufacturer, which makes it that much harder to identify the type of unit that it is.
    Thank you for your effort and time in helping me with this problem.
    Eduardo Mosquera
  • damtramp Dec 12, 2008
    some floor jack same problem
  • Anonymous Jan 25, 2009
    Hi Chris I have a 1.5 ton Sears jack and the seal inside has gone bad (N80XXXX) Do you know where I can find this seal? thanks Ron
  • Anonymous Apr 22, 2009
    I have a sears 5 ton hydrolic jack that won't lift. Model 3 is 214-50114. Do you have any ideas where I can get new seals?
  • Anonymous May 04, 2009
    same jack issues
I had the same problem with a 3 ton sears jack and here is what I did. I pulled the jack all the way to the top, the piston should be fullley extended. Then I added oil to the jack. You will have to work the piston back and forth, (.5 in or so) and continune to add oil while doing this until no more air comes out. The method fix my 3 ton jack. Hope this helps
Posted on Jun 08, 2009
  • Horsetooth Dec 09, 2010
    I did solution 2 and it worked perfectly! Thanks jkm4598002
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
Posted on May 21, 2009
  • 726 Answers
Oh ok i see whats wrong if u filled it with oil and realesed all the air out should be good if no go there is only one more problem that it can be
the 2 seals inside the jack one is a decent sized o ring
and the other is a rubber stopper to build up the pressure
to fix this problem the actual pump must be pulled out of the jack i have done this before but it is sorta hard if u need further help i can send u a diagram on how to do it thanks from chris
Posted on Sep 27, 2008
  • Scott Ocampo Jun 14, 2013
    can you send the diagram, I am having this problem. Thanks
I got a Sears 4 ton floor jack that someone had thrown out because it didn't lift (it was almost unused, but out of warranty). I noticed a phone number for the distributor, the Torin Jack Company, Ontario, CA (888-448-6746) on the underside of the jack. They told me to bleed the jack (open the valve - two turns CCW of the handle, and pump the handle 20 times). This fixed it; the jack works very well, at least for now. Also, the screw with the "DO NOT ADJUST" cap is the pressure relief valve. If you have messed with it, as I had, you want to adjust it "almost tight". If it's loose, the jack won't lift or will not stay up. Adjust it just tight enough so that the jack will lift and hold, but not any tighter. Hope this helps.
Posted on May 11, 2011
How to replace motor mounts on 2003 hyundai sonata
You really need the car on a lift or tall jack stands to do this. You will need a full set of hand tools, a good hydraulic floor jack, a set of Jack stands (AKA Safety Stands) and a 1.5 Ton bottle jack. Raise the front of the car as high as possible and unbolt the old mounts from the engine and engine cradle, then Carefully using the bottle jack (put a piece of wood on the plunger of the jack to avoid damage to the oil pan) raise the engine off the mounts and remove them, and reverse install new mounts, time about 2-3 hours to do the repair.
Oct 12, 2016 | Hyundai Motor 2003 Sonata
How to overhaul/ repair a hydraulic floor jack?
Sounds like a bad seal on that plunger that pumps up and down. That plunger should unscrew and then it's pilled out , there should be an O ring. That is where it probably is leaking. You probably need to top off oil. You can jack oil in an auto store or Lowes, etc.
Jun 08, 2014 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
What is a jack lift?
"A jack lift is a mechanical device used as a lifting device to lift heavy loads or apply great forces. Jacks employ a screw thread or hydraulic cylinder to apply very high linear forces.
A mechanical jack is a device which lifts heavy equipment. The most common form is a car jack, floor jack or garage jack which lifts vehicles so that maintenance can be performed.
More powerful jacks use hydraulic power to provide more lift over greater distances. Mechanical jacks are usually rated for a maximum lifting capacity (for example, 1.5 tons or 3 tons)." (Wikipedia)
Oct 07, 2013 | Hoisting
How does a floor jack work
Place jack under what you want lifted and close valve and put rod in jacker and jack up till your height is good,to let down turn valve counterclock wise.
Sep 13, 2012 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
My Sears 3 ton high lift floor jack will raise but it won't lift any weight. The jack is only 3-4 years old and it has not had much use. I can't find my owners manual, and I want to know what I...
Sounds like it needs some hydraulic fluid added.Look for a rubber plug or screw on the side of the hydroelectric cylinder where the ram comes out.Buy a zoom spout oilier and save the oil.Use some solvent and clean it out.Add some hydraulic fluid and fill until it starts to come out.You may be able to find an oil can that will work for you. Leave the jack in the closed position when you fill it.
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
May 19, 2011 | Garden
I have a Pro-lift floor jack - model #F-388P - (2-1/4 ton, 4500 lbs). It is leaking hydraulic fluid where it compresses the fluid (where the piston compresses the fluid - the gaskets leak). Can you...
Try here - this is the PDF for one of their jacks, but contact info is on lower right side
Mar 09, 2011 | Garden
What Jack and stand to get for my '04 Ram 1500 Short Bed V6?
Mar 14, 2009 | 2004 Dodge Ram 1500
Need a lift
hi, i always recommend using a lift kit for safety but, you can use a hydraulic floor jack to lift as well. they are really strong and sturdy. i would recommend using one hydraulic floor jack on each axle.
Mar 04, 2009 | 1995 Dodge Dakota
Hi i have a 3 ton sears floor jack i can not
I think I have the same jack. Th serial number was on a little sticker that is long gone,but the model number you need might needs is: 875.501390.
Hope this helps.
Mar 01, 2009 | Plumbing
Plumbing Logo
9,549 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
