Question about HP LaserJet 1018 Printer
Printer is not being recognized by the system
At the end of the hp driver installation wizzard it is supposed to recognize the printer connected at the usb port. in this case it doed not! i have checked all the connections ( power, usb). the system is not able to see the printer at all. this usb port works fine with all the other devices. therefore the problem is not really with the usb port. this is a new printer. PLZ help!
    Problem Solver:
  • 11 Answers
Problem with usb connector in logic board of printer.please check the continuty of four tracks of usb cable to board.
Posted on Oct 11, 2008
My printer is offline
do you have original CD with you? Un install the drivers, run the CD, connect printer when dialog box appears to connect check system recognized?.. yes do rest of the installation process.. check for the print..If printer not recognized, formatter faulty, buy new printer...
Feb 01, 2012 | HP PSC 1210 All-In-One InkJet Printer
Hp deskjet f335 all in one printer will not let me print anything off of my computer
Un install the drivers from the system, connect the printer if its recognizing the printer, install the drivers.. If not recognizing replace formatter...
Sep 10, 2011 | HP DeskJet F380 All-In-One Printer
I downloaded the driver that is supposed to work for my windows 7 computer, but it does not recognize that a scanner exists.
Good Day Imberi!
You have to browse the software driver that you downloaded and look for scanner driver. Run the installation again.
If the software driver is not complete, you can download here: You must select first the operating system and look below the drivers.
First of all, the HP C6380 must be connected locally from the PC that you are using. You can then use the scan option from your printer or scan option from the control panel of your system.
Let me know if you want me to help you further.
Jul 28, 2011 | HP Photosmart C6380 All-In-One InkJet...
Computer did not detect the usb attached printer. usb port is in working condition. ( usb device has malfunctioned and window does not recognize it )
ensure that the driver for your printer is installed.
and create a printer in printers.
use your printer wizzard to do this.
once the printer is created connect the printer using the usb cable.
then right click the printer icon in the list or follow wizzard to print a test page
once this printer is in your printer list, you can right click the icon and set it to default printer.
this will then be the printer all programmes will use when printing. or you have to select it when you press print in the file menu of your programme to select which printer you want to use.
I hope this was helpful.
Jan 24, 2011 | HP Office Equipment & Supplies
I want to connect a HP P4014n Laserjet Printer up to another computer but I do not have this installation disc, how can I get this printer working on another computer?
download the driver / software from hp website.
if your system is connected to the network / router, your system should recognize your laptop or another system (same workgroup).
add new printer see if the system recognizes else. add the printer by providing the printer ip address. (test print from your printer and will provide the ip address)
Sep 02, 2010 | HP LaserJet P4014n Printer
HP Laserjet P3005N not recognized
http://www.hp.com/cpso-support-new/SDD/main.htm?cc=us&lang=en
This is HP's driver checker,it will check your system and make sure the correct driver is installed.
Jan 08, 2010 | HP LaserJet P3005n Printer
Unable to transfer video!!
You must install the software that was shipped with you camcorder. It installs drivers that allow the computer to recognize it.
Install software, Then connect the camcorder. The hardware wizzard will install the drivers for you automatically.
Hope it helps
Sep 11, 2009 | Video Cameras
Can't install old printer on newer computer
The appropriate printer drivers are bundled with XP. With the printer connected to the computer and powered on, the system should automatically recognize the printer and install the correct drivers if it is connected via USB. If it is connected to the parallel port, go to Control Panel -> Printers, select Add New Printer and follow the on-screen prompts.
Mar 21, 2009 | HP DeskJet 932c InkJet Printer
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
HP 845C
Try turning the printer on while it is connected and see if the computer recognizes it. Once it does it will prompt you for the driver. Now you should be able to install the driver.
Jun 24, 2008 | HP DeskJet 845c Printer
343 people viewed this question
Seeker5211
Seeker5211
