Question about Intel D845GVSR Motherboard
Ram not working
Two ram with same speed but in my p4 2 4 computer it take only one at a time
  • 476 Answers
Have you set your bios to auto recognise the ram?
what Operating system are you running thanks
Posted on Sep 27, 2008
775i65g vga
some graphic cards are made for speed, they have their own rams, processor's and fan's, also as time goes by, ya have to update your driver's, try updating them, also, most computer come with 4 gig's of ram, this also helps the speed of your computer, random access memory, is temporary, not store memory , try adding more ram's
May 04, 2014 | ATI Computers & Internet
RAM cannot be detected
If you are installing two or more RAM modules try to use the same make and speed RAM ,sometimes mixing RAM from different manufacturers won't work.
The RAM module may be faulty, try inserting one RAM module at a time to see if each RAM module works before inserting all the RAM modules.
Check the motherboard manual to see if the RAM meets the specification.
Aug 25, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I want to upgrade the standard 512mb RAM to 2GB. once installed do I just restart the computer or do I need to do something to allow the computer to recognize the new RAM?
You should be fine to just turn the computer on straight away as soon as you have installed your new RAM. The computer will recognize the new upgrade straight away provided you have got memory that is compatible with the desktop computer.
When you upgrade the RAM take the old RAM out and make sure your new RAM runs at the same speed as your old RAM.
From what i can remember the maximum RAM speed that an HP pavilion supports is 400MHz although it could well be 333MHz.
The RAM that's installed in the desktop at this moment in time will have the speed on it so you check with that.
Regards.
Jan 25, 2010 | HP Pavilion a450n PC Desktop
Will additional RAM increase the speed of my computer. I have the original 512mb?
Increasing the RAM on your PC will considerablly increase of your system. The RAM is your computers work sheet. Whatever you see on the screen of your computer is first stored on the RAM. If the RAM is small, it gets fill easily with data. Older data on the work sheet not being currenty accessed is move to the temporary area on the hard disk. When this data is needed the older data move to the same temporary area for this data to be displayed. This impacts on the response time of the PC which you see as the system bring slow.
Inceased RAM will increase the work sheet area and reduce the rate data is move to the Temporary area of the Hard disk thereby improving the PC Speed.
More importly if you wand to improve the speed of your system, check the applications you are running against the system requirement of these application. Follow the recommended system configuration for all the application and you system speed will not be impared.
Jan 08, 2010 | HP Pavilion 725n PC Desktop
BOARD RUNS REAL SLOW
i think it is not true. because speed of computer depend processer and ram . u can chang high config . ram than using . it can help little make high speed. temp file can make slow so time by time we remove this file. virouse can make slow computer. if bord is short it make hang computer.
Nov 04, 2009 | Computers & Internet
Ram wont work with computer
Dear user in my observation this is sauses due to two different bus speeds. i mean both RAMs dont have the same bus speed. thats why both RAMs dos'nt work at the same time. hopfully u will understand it
Apr 23, 2009 | Computers & Internet
PC wont boot
It seems that one of your DIMM slots on your mobo has conked out, sorry pardner but might have to end up changing the entire mobo. Also try out your old RAM sticks on another PC for confirmation.....sodeep
Apr 05, 2009 | HP Pavilion m7640n PC Desktop
Hi Have a Dell Dimension 8200 trying to increase memory Original is 2x128 plus 2xcontinuity Purchased 2x256 and installed but computer will not work.Is it the case that I can only install another 2x128...
On a Dell Dimension 8200 there were 2 available bus speeds, 400mhz and 533mhz. The bus speed determines the required RAM speed. Most common 8200's have a 400mhz fsb and require a RAM speed of 45ns or faster (Lower number = faster). Some 8200's have a 533mhz fsb and require a RAM speed of 40ns or faster. The RAM modules must be installed in matched pairs, but the 2 pairs do not have to be equal to each other. (I have 8200 with 2x512mb and 2x64mb - you can also mix ECC and NON-ECC pairs but it will disable ECC) Check the last 2 numbers on your original RAM that works in your system, they will be either 40 or 45. If they are 40 - and 45's won't work, you have a 533mhz fsb. If this is the case, buying the same RAM in a 40ns speed will solve your problem...... Hate to be the one to break it to you, but if you do need 40ns (Rambus) RAM, it is very expensive - about 4 times the price and 1/10th as common as 45ns RAM. Some good deals can be found on ebay - search: rambus 40ns.
Hope this helped, and good luck :)
Jul 16, 2008 | Dell Dimension C521 PC Desktop
Hanging after booting
Hanging is just a minor problem of any pc. It just means that the system is hot. Just open up the system unit and make sure that the cpu, system and power pack fans are working. Also clean the system because of dust.
May 27, 2008 | Intel Motherboard
My First RAM Upgrade-Any Tips
Ah you have found out one of the great things about confusing naming standards. Often times, 200Mhz memory is called 400Mhz if it is DDR because DDR stands for "Double Data Rate".
It still operates at 200Mhz speed, but since it doubles the data it is sometimes refered to (wrongly) as 400Mhz.
On the upside, all DDR-I ram is backwards compatible. So there should be no problems. However sometimes different memory sticks dont play well together.
What I would do is this:
1) Shutdown computer, UNPLUG computer - wait 5 minutes
2) Open computer
3) Remove old Ram stick and replace with the new stick
4) Replace cover, plug in and boot to windows.
If everything works fine, then do step 1-2 again, but this time add the old stick you removed before, and place it in the unused slot.
Again check that the computer functions properly. If it does not, remove the old stick.
Nov 22, 2007 | Gigabyte GA-8IGX Motherboard
Intel D845GVSR Motherboard Logo
24 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
