Question about Intel Motherboard
A problem when i turn off my computer
Hi i have a problem when i turn off my pc after about four second the pc will work again it self and it would not stop until i sparate the electricity from it
of course i use gigabyte 945 s2
  • mrm-mlm Sep 27, 2008
    the problem in the post thank you so much
    Problem Solver:
  • 29 Answers
Most PC's have a four second delay in the on/off switch. Make sure you are press and holding for a full four seconds.
rmatheson@wowway.com
Posted on Sep 30, 2008
Dell pc turns its self off
your PCs energysystem are proberly made to save energy.this can be
changed in the contrlpanel loo under energyprofiles.
there of the change of powerlight colour.
Apr 22, 2013 | Dell Dimension 4600 PC Desktop
Why is my computer turning off after 10 seconds when i turn it on?
The 10 seconds of boot is part of the process called POST (power on self test) This test is comprised of testing for power, motherboard, memory, and video card. So tests these components and see if any of them is not working properly. You can also check for overheat problems and power supply issues.
Hope this helps.
Jul 30, 2011 | Dell Dimension 2350 PC Desktop
Computer comes on for about 10 seconds ant then turns itself off
hi,
Hope this helps.
I have sony DSC-S500 digital camera i want to know how to take a photograph using self timer thank you Regards Sailaja
For capturing the images using Self Timer, press the Down Arrow control button continuously to select the desired mode. You can set the timer for 10 seconds and 2 seconds by pressing the continuously, If we press the button again the Self Timer will be turned off.
Press the Shutter button, the self-timer lamp flashes and a beep sounds until the shutter operates. To cancel the self-timer, press the down arrow button again. You can redice the risk of blur by using the 2-second delay self-timer.
Good Luck!
KenSolutions
Oct 30, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
How do i net work four computers to the internet
Hi For connecting four computers to the internet,you can use two ways
1. Connect 1 PC to net and then share connectivity 2. Use a router, connect the router with internet and connect all the PC's to the router so that all will enabled with internet
Better go for the second option as it will ensure a more reliable and error free network
Thanks
Oct 18, 2010 | Computers & Internet
Four beeps wont turn on, Dell 4700
The four beeps usually indicate a memory problem and it won't pass it's Power On Self Test. Try reseating the memory sticks, or, if you have two of them, take one out and try to start the machine and then swap them.
If this doesn't solve the problem, you most likely have a bad motherboard.
Feb 01, 2009 | Dell Dimension 4700 PC Desktop
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
I have a hp pavillion entertainment laptop and i try the power button and the computer turns on but after a couple of seconds it turns it self off and then trys to turn its self back on again it wont get...
try hitting F8 before windows attempts to load to enter the boot manager, from here you should select last known working configuration, if that fails, do the same except boot safe mode
Feb 13, 2008 | Computers & Internet
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Intel Motherboard Logo
32 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
