Question about Nikon COOLPIX L12 Digital Camera
Problem with the Flash Light of Nikon COOLPIX L12 Digital Camera
I brought a Nikon COOLPIX L12 Digital Camera a few months back. one of my friends borrowed it from me and used it turning the flash light option off. when i tried to use it after that the flash light is not working and the perfection of picture (quality) seems to be not the same as earlier. i'd tried to solve the problem using the manual provided by the company, but failed.
hope someone can help
    Sergeant:
  • 208 Answers
I know some of the common things for the digital camera. I want you to try these.
-------->If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
-------->Set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness.
IMPORTANT: If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
* When shooting MPEG movies
* When set to the Twilight mode
* If an external flash is connected
The information above should resolve your issue. However, if the issue still persists, you can try resetting the camera to factory specifications.
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings.
Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to reset the default settings. Otherwise, continue with the manual reset procedure below.
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
If all the above fails you, then i doubt that Impact damage would have caused the flash not to work.
But i know you are not going to like this solution. No other way , you have to contact Nikon service centre for repair.
i hope this helps to fix your problem.
Thanx for using fixya.
Cheers.
Posted on Sep 27, 2008
How do you transfer photos from Nikon Coolpix L12 camera internal memory to the memory card
by usb to your pc and then onto a memory card is probably the easiest way of doing it, unless something is preventing this course of action
May 30, 2015 | Nikon COOLPIX L12 Digital Camera
Why unable to upload photos from camers to computer?
probably need to install a driver on the computer
http://www.solvusoft.com/en/update/drivers/digital-camera/nikon/coolpix/l12/model-numbers/
Nov 27, 2014 | Nikon COOLPIX L12 Digital Camera
I cannot import my pictures from my L12
Having gone over a month without a response, I assume my suggestion helped.
Jul 19, 2010 | Nikon COOLPIX L12 Digital Camera
My camera nikon coolpix l12 keeps saying lens error,what should i do
This is a serious problem with Coolpix cameras. If it is still under warranty then take it to a warranty repair facility for Nikon.
If it is not under warranty you could try removing the battery for a few minutes, put it back in and try the camera again. As a last resort before tossing the camera out.....CAUTION DOING THE FOLLOWING MAY RESULT IN PERMANENT DAMAGE TO YOUR CAMERA, DO THESE AT YOUR OWN RISK.... Other remedies that may work would be to gently tap on the sides of the camera to see if you lens may be stuck in a certain position. Or, you could gently and slightly twist the lens back and forth.... VERY GENTLY though. This may free up the lens and allow it to work.
I hope some of this works for you and good luck.
Nov 14, 2009 | Nikon COOLPIX L12 Digital Camera
Flash doesn't work on nikon coolpix l12
I actually just fooled around with mine because it was doing the same thing. It will only flash in the scene mode, but not the normal quickshot mode. i noticed under the camera symbol on the screen said BSS and i went into the menu and clicked on BSS and turned it off b/c it was on and that worked finally.maybe u can try it, if its the same situation.
Jul 20, 2009 | Nikon COOLPIX L12 Digital Camera
How do you delete all pictures simutaneously from Nikon L18 camera?
Hi - You can download the manual by clicking the link underlined in blue below:
COOLPIX L12
See page 88
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Oct 12, 2008 | Nikon COOLPIX L12 Digital Camera
Nikon COOLPIX  L12 Digital Camera Logo
213 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
