Question about Canon Office Equipment & Supplies
I have a Canon StarWriter 80 and it won't feed paper when I press the "paper feed" button. If I can't repair this is there a service center where I could get it repaired in central California? Gary A. Beeman gbavian@comcast.net
ohms
  • 1879 Answers
SOURCE: I have a Canon PIXMA
Greetings,
If your are not loading from the ADF, check the settings and see if it is set to get paper from the Auto-Sheet Feeder.
Sometimes having an equipment repaired costs more than buying a new one.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jul 20, 2008
  • 6 Answers
SOURCE: new dell printer 926 does not feed paper need repair manual
is it under warrenty? contact the vender if it is as you may void the warrenty if you try to fix it yourself
Posted on Feb 27, 2009
Joed911
  • 4338 Answers
SOURCE: Ink absorber is full.
Try this:
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
sherlyn c
  • 134 Answers
SOURCE: I need a repair service for EPSON stylus photo
Please log on to epson.com. Click on north america, then usa. Go to the drivers and support page. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
Posted on May 04, 2009
  • 121 Answers
SOURCE: Paper feed button flashing
Check your user manual for resetting the printer to factory default settings.
If that doesn't work, unplug your printer from the computer and uninstall your software through Add/Remove Hardware. Shut down your computer and reboot. Reinstall your printer software, following the instructions carefully.
This should clear up your problem.
Let me know if you still are having problems. :)
Posted on Oct 08, 2009
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
Paper won't feed from tray canon mp760
check in your front panel the button "Feed switch"
If you press the butto, the led change to show where the printer get the paper
If led up, you must place paper on Autosheed feeder
If led down, you must place paper on tray Cassete
If the error continue. check if they are Jam paper .
Is important for people who share their knowledge, know your comments. If the answer is helpful, rate my answers
Sep 27, 2011 | Canon PIXMA MP760 All-In-One InkJet...
I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
If you do not have a manual it can be downloaded from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
Issue: More than one sheet of paper feeds while printing
Solution: Clean the paper feed rollers using the MX300 operator panel
sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
2. Clean the paper feed roller.
(1) Press the Menu button repeatedly until MAINTENANCE appears.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
The paper feed roller will rotate as it is cleaned.
3. Repeat step 2 twice.
4. Open the Paper Output Tray.
(1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
(2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
Set the Paper Thickness Lever to the left.
6. Repeat step 2 three times.
The paper cleans the paper feed roller as it feeds through the machine.
If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
Dec 25, 2010 | Canon MX300 Office All-In-One Printer
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Why doesn't paper feed after "print" instruction? Printer merely makes a mechanical noise and states "paper out" condition.
Hello.
There are lots of reasons why this would happen:
Foreign object (could be very tiny)
Any power lights flashing ?
Paper feed rollers may need cleaning - try (from Canon Support):
1. Ensure that the printer is turned on. If any paper is loaded in the printer, remove it.
2. Select which roller to clean, the auto sheet feeder's or cassette's, by pressing the <Paper Feed> switch on the printer.
3. Hold down the <Resume/Cancel> button; when the Power lamp flashes green three times, release the button. The paper feed roller will rotate as it cleans itself.
4.. Repeat step 3 twice.
5. Load three or more of A4 or letter sized plain paper in the auto sheet feeder or cassette, as selected in step 2.
6. Repeat step 3. The paper that is loaded in the printer will be fed through the printer and ejected.
7. If printing problems persist, repeat step 6 up to three times.
Could be a hardware error and the printer would need servicing - still under warranty ?? If so, return to Canon for repair or replacement.
Hope this helps.
Jul 05, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
My canon starwriter will not read 3'' floppy discs...please help.
I cannot solve your problem but I have a Canon Starwriter 80, in great working order, for sale, if you are interested. Email me at wagtail@chartermi.net
Sep 08, 2009 | Ultimate Sound Office Equipment & Supplies
Canon Pixma iP1500 printer indicates paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 22, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon starwriter 400 won't print
Usually the problem is a plugged cartridge.
It is possible the ink cartridge is empty.
It would be best to buy another cartridge and try that first.
Dec 14, 2008 | Office Equipment & Supplies
Error msg: Paper tray empty or jam, when there is not
Clean The Paper Feed Rollers Using The Unit's Operation Panel Ifthe paper feed roller is dirty, paper is not fed properly because thepaper feed roller slips. Cleaning the paper feed roller could resolvethe paper feeding problem. Please follow the instructions below toclean the Paper Feed Rollers directly from the unit. Caution:Since the cleaning process wears down the paper feed roller, performthis procedure only when necessary and no more than three (3) times.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  1. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  2. Tocheck if the rollers are clean, load a sheet of Letter-sized plainpaper in the same paper source you selected in step 2, and press the<Open> button.
  3. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Sourcesetting in the printer driver. If the option is not set to 'Paper FeedSwitch', paper will feed from the source selected in the driver.
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
55 people viewed this question
old marine
old marine
