Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Blinking green light
Any suggestions on next step after replacing the caps and the light still is blinking?
  • Mitsubishi Master
  • 8,617 Answers
Depending on the severity of the caps there are two fuses on the DM that could be blown.
Posted on Sep 27, 2008
Vaio desktop blinking power supply
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector and next to a green blinking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
If the steps above don't work you will need to get a new power supply.
May 19, 2012 | Sony VAIO VGC-RB42G PC Desktop
Mitsubishi 65" WS-65869 Blinking Green Light 3-2 pattern,
two ideas:
Make sure you tested the pico fuses inside the unit with the caps==two or three of them.
Also from front of set behind speaker grill unplug both plugs that go up to front keyboard--set will still work with remote===if set functions now then the reset micro switch is bad/damaged.
Mar 12, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Power went out, now the tv just blinks at me. I
Does the blinking continue non-stop forever? If it does, it is most likely the CAPS in the DM module. If you can solder or know someone who can, this is a fairly simple repair. Some sets have 4 CAPS, yours (WS-65711) should have 7 in the DM module that will need replacment. There are many step by step sets of instructions on how to do this repair. Google mits blinking green light of death. You will find loads of information and help.
Dec 19, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Green light flashing
The WS65813 is the V23++ series. The blinking led means the DM caps have failed you can get the V23 DM repair kit at the following link which contains the replacement capacitors and step by step instructions with pictures so you can do the repair. Heres the link its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Feb 16, 2009 | Mitsubishi WS-65813 65" Rear Projection...
Mitsubishi ws55513 Blinking green light- replaced capactitors
Hi again,
It would seem that you posted twice. My compliments on accomplishing the replacement of the 4 1000 uF/16V capacitors on the DM board.
Toyour concern, the blinking is still there even after having replacedthe caps, a friendly reminder, the capacitors are polarized, there arespecific +/-. Additionally, you may have to check the pico fuses. Theywould be on the backside of the DM board and would be very close nearto the solder points of the 4 caps. They are marked FB900, FB901 andFB902. Rating would be 125V 4amp. Possible source maybe here.
Justa start, do postback how things turned up or should you need additionalinformation. Good luck and Thank you for using FixYa.
Nov 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Green light will not stop blinking
often the capacitors will show no visible sign of swelling. 90% of the time the blinking light symptom is caused by those capacitors
May 12, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Green led light on for 3 seconds then off, will not power up
Blinking Problem
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Dec 15, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
