Question about Acer TravelMate 2300 Notebook
  • Anonymous Nov 16, 2008
    I have a Aspire 3620 and have the exact same problem... need a new lid and screen now because acer said it had been dropped even though it was only the plasitcs on both sides that had been broken
  • 169 Answers
Your best best is to search eBay. That's where I find all the accessories I need to replace LCD's, hinges and covers for my clients.
Hope this helps - remember to rate!
Posted on Sep 30, 2008
Faulty lid on HP Pavilion M6-1009TX notebook laptop
Hello friend, if one or more are broken, you will have to replace such as here :
Youtube often has Video "how to's " to show how to dismantle / change hinges for your machine.
Aug 20, 2014 | HP Pavilion m6-1009tx...
Hinges broken, power supply borken, bottom case replace
And you question is? Sounds like you need a new laptop.
Feb 27, 2013 | Computers & Internet
Change inspiron 1721 lid
Do you mean the LCD screen with the lid?
If so you undo the hinges and disconnect the video and power leads to the inverter.
This WEB site shows how to remove the screen/hinges.
Replacing Display hinges
Apr 28, 2012 | Dell Inspiron 1721 Notebook
Mu laptop hinges are broken. I wanted to know what problems this may cause? Sometimes when I tipe words, it doesn't work in the screen. This could be related with the broken hinges?
Laptop hinges are generally made of low-cost metal alloys, or "pot metal yeah this may cause problem you can fix your broken hinges easily by spending little time ." Pot metal is not particularly durable, and over the course of a laptop's life cycle, repeated opening and closing of the computer's lid can cause wear that prevents the lid from staying in an open position. Hinges can also wear to the point that they break at the point of attachment, either on the lid or the computer's body.
Hinges are usually attached to the computer's frame via machine screws. In order to get the most life out of your computer's hinges, it is not a bad idea to perform a yearly inspection. Remove the hinge covers and check that the machine screws that secure the hinges are tightened fully. If screws are missing, contact the computer's manufacturer to order replacement screws; hinges missing screws are subjected to additional stress and can wear out faster if steps are not taken to replace the screw.
Lubrication of the hinge is possible, but not recommended; if the wrong type of lubricant is used, it could damage the computer's case or seep into the electrical components and further damage the computer. Consult a professional technician if you feel that your hinges require lubrication.
o Hinges can also be damaged when the computer is picked up by its lid, dropped from various heights or opened beyond the angle at which it should stop. In these situations, damage to the hinges may be of secondary concern, as component damage and data loss might have occurred. Depending on the amount of damage and warranty status, the computer may require complete replacement.
Laptop hinges are not indestructible, but their coverings and trim may show wear long before the hinges are actually in any danger of failure. Most laptops on the market include plastic hinge covers. The hinge covers can develop stress fractures from repeated wear; most of the time, this is not indicative of a hinge problem.
Some laptop hinges are housed within the bezel or trim of the computer's monitor or body. This, too, is generally made of plastic, and might develop stress cracks after a few years of use. Hinge covers and bezels are usually modular, and replacements are generally easy to find at low to moderate costs.
o Hinge problems can be mitigated with adjustments to the hinge's tension or additional hardware installation by the user. Brackets can be installed on the outer case to allow for hinge-like performance, or the screen can be mounted in a fixed position. If the screen is left permanently open, care should be taken to prevent damage to the screen and to prevent dust accumulation in the keyboard.
The lid and screen assembly can also be replaced, if the correct parts can be found. Replacement of the lid and screen can be cost-prohibitive, with parts and labor sometimes exceeding the cost of the computer.
Sep 01, 2011 | Computers & Internet
Hi, I have HP Compaq Presario CQ40 model laptop.From Yesterday the monitor display is not working.I tried pressing the hinges nearby the webcam are and able to view the display on holding(pressing)...
The display connectors are either loose, or you more likely have a broken solder joint, as you bend/flex the lid, you make the contacts touch and get the picture back, you need to take the lid assembly apart and check.
Sep 03, 2010 | Compaq Computers & Internet
Broken Inspiron 1525 Lid
To fix your laptop follow the steps given below.
  • First of all as your hinges are broken you have to buy a pair of hinges for your laptop model.
  • This hinge includes the whole assembly made up of metal with a part which attaches your screen to the laptop.
  • Now you have to open up your laptop from the backside and disassemble the upper side.
  • This will make you see the part which detaches tour screen from the laptop.Just remove the screws and your screen will be completely detached.
  • now you can replace the damaged hinges with the new one.
  • you have to remove four screws for one hinge.Two screws supporting the screen and two attaches the screen with the laptop.
  • so remove these screws and replace the hinges and pack the laptop again.
And the lines are basically due to the movement of loose connector. So while fixing please fix the connector also.
Thank you
Aug 21, 2009 | Dell Inspiron 1525 Notebook
Tightening HP Pavilion DV9000 17'' LCD Hinges
you may find the hinges parts from eBay which is cheaper price:
how to replace your laptop hinges:
1) take out the screws at back of laptop under the hinges base
2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
3) there are two cables connect between LCD lid and laptop base
you do not need disconnect those canbles. just careful them
4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
6) put back all screws step by step.
hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
May 18, 2009 | HP Pavilion dv6000z Notebook
The lid on my top loading admiral mega 22 plus washing machion is
These are plastic and will need to be replaced with new.
Once you have sourced new hinges then the machine top needs to be opened,
Electrically Isolate the machine, then at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the screws on the hinges and replace with new.
Mar 03, 2009 | Admiral AW22 Top Load Washer
Cover of laptop
do you mean the lid falls off has it been broken in half that would cause it to do that? please explain more the cover is the lid Im thinking of??????????
Sep 30, 2007 | Toshiba 2405-S221 Notebook
Compaq presario 1200
there are plastic covers over the hinges, which may be part of the faceplate. being a compaq the hinge screws are most likely torx head screws. compaq used to make a special tool for removing the plastic covers on their laptops. the tool was a bar with a piece of fiberglas circuit board embedded in it. you insert the circuit board into the groove between the top and bottom covers and twist. this is, of course after removing all of the cover screws. some of the cover screws on the display may be hidden under rubber bumpers.
Jun 28, 2006 | Compaq Presario 1200XL104 Notebook
Computers & Internet Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
