Question about New Home HF-2022
Can't bring up the bobbin thread
I have a e-10 huskystar and i can not get the bobbing thread to connect with the needle thread, help
    Novelist:
  • 371 Answers
Sounds like hook/needle timing is off. Check it by doing the following with the power off:
remove bobbin, bobbin case, and needle plate.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins.
Make sure the bobbin is unwinding in the correct direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Posted on Sep 26, 2009
  • 98 Answers
Try threading the bobbin at the slot on the left side of the "latch", then move up to the next slot and pull it down into the slot, then you are ready to pick up the bobbin thread with the top thread. The bobbin thread will be drawn across the top of the bobbin and will be outside the bobbin compartment after the thread is pulled through.
Posted on Aug 03, 2009
The bobbin thread will not raise with the needle
1. REPLACE NEEDLE W/FLAT PART AWAY FROM YOU.
2. MAKE SURE THE TOP THREAD IS PROPERLY THREADED.
3. INSURE BOTTOM BOBBIN IS ROTATING RIGHT DIRECTION. (USUALLY COUNTERCLOCKWISE) ALLOW THREE INCHES OF THREAD PULLED AWAY.
4. HOLD TOP THREAD W/LEFT HAND AND ROTATE HAND WHEEL TOWARDS YOURSELF. DOES IT BRING THE BOBBIN THREAD UP?
5. IF THE BOBBIN CARRIER IS INSTALLED PROPERLY THE HOOK (POINTED OBJECT) UNDER THE BOBBIN SHOULD "HOOK" THE TOP THREAD AND BRING THE THREAD AROUND THE BOBBIN THREAD. THE NEEDLE AND TOP THREAD SHOULD BE PULLING THE BOBBIN THREAD UPWARDS. IF THE HOOK DIDN'T "HOOK" THE NEEDLE THREAD THE PROBLEM IS THE DISTANCE OF THE NEEDLE AND HOOK APART OR THE TIMING. YOU MAY TRY TO MOVE THE NEEDLE TO THE LEFT SIDE AND AGAIN TRY ROTATING THE HAND WHEEL. IF IT DOESN'T WORK THEN TRY TO MOVE THE NEEDLE ALL THE WAY TO THE RIGHT AND ROTATE THE HAND WHEEL. IF IT BRINGS THE BOBBIN THREAD UPWARDS IN EITHER CASE IT WILL SHOW A PROBLEM WITH TIMING. THIS WILL NEED TO BE ADJUSTED BY A PROFESSIONAL.
6. REMEMBER TO PUT ONE DROP OF OIL ON THE RACE TRACK BEFORE YOU PUT THE BOBBIN CARRIER IN.
Jan 13, 2015 | Singer HD-110 Mechanical Sewing Machine
I'm having trouble with the bobbin. The thread won't come up and just bunches up under the plate
1. Make sure your bobbin has enough tension. Check by hanging from your finger, It should extend one inch when you bob it.
2. Set top tension starting at 3.
3. Replace needle. Make sure that it is in right.
4 Check the way you thread the machine. It must be done right.
5. Rotate the hand wheel towards you and hang on to the top thread. As you rotate there should be some pull at some point. This is the bobbin doing this. If there is pull but the thread isn't coming up then your bobbin is hanging up.
6. Monitor the bobbin while you rotate the hand wheel. The thread should move across the bobbin but not get snagged. If there is a snag you will need to readjust that part just a little. This is normally a screw that needs to be loosened and retightened.
7. If the other suggestions don't work then move the needle to the right side of sewing. Also, try by doing it on the left. If it does bring the bobbin thread up then your machine needs to be timed.
8. For timing you can go to youtube for instructions. Or go to a repairman.
Nov 26, 2014 | Sewing Machines
The thread gets caught up in bobbin area
This mess is commonly referred to as a bird's nest or 'birdnesting' and it's usually caused by incorrect top tension and that's often caused by the top thread not in the correct path. (For me, I occasionally forget to thread through the take-up lever.) A damaged needle can also cause birdnesting.
Aug 02, 2014 | Husqvarna Huskystar 207 Sewing Machine
My needle wont sew on my husky star 207?
change the needle--make sure it's the right needle for the fabric
being sewed
rethread the machine top using every thread guide
check to make sure the bobbin is not over wound, make sure the
bobbin is not warped, & that the bobbin is inserted correctly into the
machine
make sure the thread has not come off the thread take up lever
it's also possible that the machine is out of time
Jul 14, 2012 | Husqvarna Huskystar 207 Sewing Machine
I can not get my bobbin thread to sew but my top thread does on my Huskystar 207 sewing machine
have you checked to may sure the bobbin is turned the right way & inserted
in the bobbin case the right way?
try changing the needle --flat side goes to the back of the machine
Apr 05, 2012 | Sewing Machines
Bobbin thread jams
try changing the needle--flat side goes to the back of the machine
check the thread take up lever & see if the thread is still on it
it's also possible that the machine is out of time & needs to serviced
Feb 19, 2012 | Husqvarna Huskystar 207 Sewing Machine
Husqvarna Huskystar 207 Sewing Machine not stitching. It won't pull the bobin thread up to sew.
Be sure not to use Singer Needles. They are longer than standard needles. Don't know if this helps, but I did this once on my Huskystar 207 and that is what happened. It also damaged the bobbin thread.
Fairleigh
Sep 18, 2011 | Husqvarna Huskystar 207 Sewing Machine
Out of nowhere, after working fine for weeks, the bobbin thread started breaking, and then stopped "wrapping" properly around the outside of the bobbin while I sewed. It keeps jamming to where I...
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
Check tension 3 or 4 is usually good
after you try all this & it keeps jamming then it may need to be serviced
Nov 24, 2010 | Husqvarna Huskystar 215 Sewing Machine
My 5 year old Huskystar 216 sewing machine is
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
Bobbin problem: Huskystar by Husqvarna Viking E10 sewing machine
This has happened to me, even though I have been sewing for 30 yrs. When I take the bobbin holder out I realise what I have done wrong. When placing a bobbin into the bobbin holder the thread must be running around the bobbin CLOCKWISE. If incorrect take bobbin out of holder turn it over, so now the thread will run clockwise.If bobbin placed in holder and thread runs anti-clockwise, when you tried to turn wheel to bring bobbin thread up, it will either not do it at all or will make a huge tangle of the threads. Happy Sewing
Nov 17, 2007 | Sewing Machines
New Home HF-2022 Logo
992 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
