Question about Mitsubishi WS-48311 48" Rear Projection Television
Xbox 360, no display or sound on tv - Mitsubishi WS-48311 48" Rear Projection Television
  • pumpa007 Dec 24, 2008
    HDMI cable work fine, but SD cable only sound no video
  • 3 Answers
It has to do with your GPU. It is held on by X-clamps on the bottom. When they heat up they flex and it releases the presure off of the censor on the GPU. This can cause sound to go out,sound and video to go out, and can cause the red ring of death. The xclamps will need to be replaced with machine screw. Also the silver compound on both the GPU and CPU will need to be replaced. I own an Xbox 360 repairs shop and I would be more than happy to help you out. Email me at gamerguy@ctp360repairsandsales.com. You can also go to my webstie at www.ctp360repairsandsales.com. Hope this helps.
Posted on Jan 13, 2009
Xbox 360 Console: xbox 360 video not displaying but sounds works...
make sure the color cables a fastened tightly in the t.v.
May 18, 2010 | Microsoft Xbox 360 Console
We have sound but no picture on the xbox 360
The first thing to try is to remove the external hard-drive from your Xbox and see if the picture comes back. If that doesn't work you may have the video resolution of the Xbox set too high for your TV to display. Try reducing the Xbox resolution and see if you can get a picture. There is a switch at the end of the cable where it plugs into the Xbox that says TV and HDTV. Try setting it to TV. If you know someone with another Xbox 360 that you can borrow you can use it to debug your problem. If their Xbox works on your TV try swapping out the cables. You can see if your Xbox works with their cables and if their Xbox works with your cables. You should be able to narrow your problem down to either the Xbox, the cables, or the TV setup.
Jun 06, 2009 | Microsoft Xbox 360 Console
I have sound on my xbox 360 but no picture
I've seen this symptom before. Try removing the external hard-drive and see if the picture comes back. Another cause could be the video resolution setting. If the Xbox video resolution is set higher than your TV can display you will get a blank picture with sound. Try reducing the Xbox resolution if the hard-drive trick doesn't work.
Jun 04, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 sound but no picture
ARE YOU PLAYING YOUR 360 ON A REGULAR TV?
Nov 08, 2008 | Microsoft Xbox 360 Console
Xbox and tv = no sound
Yes, those cables are quite common. Check any electronics retailer like Best Buy or Walmart.
Aug 25, 2008 | Microsoft Xbox 360 Console
Xbox 360 turns on, but nothing shows on the screen
If the person that you bought it from on E-Bay had an HD Television. Then the Xbox console is set into HD from the Display options. If your TV is not HD, then It will not display. It can also be the other way around, if His TV is standard and yours is HD. Also try looking at the RCA's(The Part that plugs into the 360) And you will see a slider. Switch the slider, then turn it on. Tell me if that works, if Not, tell me and I will tell you what to press on your 360 controller to set the other menu. Hope this helps.
Jul 11, 2008 | Microsoft Xbox 360 Console
XBOX 360 - No display
Did somebody mess with the tv inputs?  Or Tv settings.  Make sure the green blue, red, cables are on good from the back of the tv set.
Oct 28, 2007 | Microsoft Xbox 360 Console
Mitsubishi WS-48311 48" Rear Projection Television Logo
690 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
