Not sure about hard reset or factory default the leads from your ((motherboard to your hard drive)) make sure they have a secure connections and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions even something as small as an electrical fan and its lead can cause you problems or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard http://office.manualsonline.com/manuals/mfg/viewsonic/viewsonic_computer_monitor_product_list.html
if you are having problems with your monitor it could be related to your computer
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
you might be able to find something in this manual
hope this helps you
