Question about Boston Acoustics BA790 Computer Speakers
Need help no sound out of speackers
I have a 3 speacker set os Boston Acoustic BA970 when i conect them to my lop top i dont get eany sound.
  • 258 Answers
Presume you mean 790 not 970, if so you can download a manual under product detail on this page.
http://www.amazon.com/Boston-Acoustics-BA790-Multimedia-Computer/dp/B00005AR7N
Check power supply is plugged in correctly and switched on at the socket, then turn or push the button usually on the right speaker to turn it on,
good luck HPC
Posted on Feb 04, 2009
Hi, The blue light temporarily comes on like it is going into protect mode and then shuts off. I do not hear the relay click. I measured the input voltage and it is at 12v and when the power is switched...
hi ill try helping .
protect is something that stops ur amp from blowing , so there is somthing melted or speacker wires touching inside box , speackers could be blown an it some times is in the speacker itself ,but there is something because i have a 600watt sony with 2 10 clarions an it hits an the voltage reads almost 13 an stays when i turn it on hope this helps a little
Jul 12, 2011 | Hifonics Brutus BX 1205D Car Audio...
The speacker is not working, give me back this diver
Hi, try this link for your sound driver: http://support.dell.com/support/downloads/devices.aspx?c=us&cs=19&l=en&s=dhs&osl=en&SystemID=DIM_P4_4600&os=WW1
Aug 01, 2010 | Dell Dimension 4600 PC Desktop
Same HP/pavilian speackers and low soung from gx280
save your polks,go to the nearest truck stop store and purchase a set of little loud mouths their called,i guanantee you will hear those.
Jun 15, 2009 | Dell OptiPlex GX280 PC Desktop
Kdc-519 install in 93 mustang
if u have cut the factory harness, then u may have cut the power on wire for the factory amp
Jun 07, 2009 | Kenwood KDC-519 CD Player
How do i wire 6x9 from the back shelf to the head unit using new wire where do i wire it on the head unit?
if you are going to place the speackers into the rear shelf than you can run your wires along the underside of the shelf,then towards the back of the rear seat, then run it down the length of the seat, when you reach the bottom you will need to try to pry the backrest portion seat foward just enought to get the wire thru to the front, then you will need to get either a phillip or slotted screwdriver, open the back door and at the bottom unscrew the trim from the bottom of the door way,run wire thru do the same with the front door, then run wire behind the trim around or near where the emergency release handle is at, run wire behind instrument panel towared your deck. when you go to wiring up the deck and speakers check on the deck to see if it has a wiring diagram on it if not: most decks come as follows ( white wires front right ,blue or purple rearl left, brown front left, grey rear right red is + black is - yellow is constant +( always on so your deck is able to stay programedwith your presets and audio settings and clock)one single blue or purple wire is the remote for your ampif the colors dont match the ones on your deck then hook up your deck to the power only when the deck comes on go ahead and set your speackers to only the rear right speacker and take your wires from your speacker and touch them to the wires on the back of the deck, once you hear the audio coming thru go ahead and mark this as right rear or rr then using the same speaker change the settings to rear left speacker and do the same as with the other one mark it rl and do same for front speackers
Feb 28, 2009 | Pioneer TS-A6962R Car Speaker
What is the proper way to connect to home theater system?
Does the Sub have a Low- Level input? This is a RCA type female connector, what you need to do is run a Male RCA cable from your home theatre where it says Sub-OUT and go into the Sub woofer Line in. Unless you only have speaker wire inputs on the back of the Sub then take the Left and Right front into the Sub speaker inputs and then out of the Sub speaker OUTS back to your speakers.
Feb 28, 2009 | Omage BB08 Subwoofer
CHEAP SPEACKERS
The best speakers are the ones that sound best to you.
You should visit a hi-fi or dj equipment dealer and ask him/her to demonstrate some of their stock to you.
Take with you one or two discs of your own that you know well to listen to on their equipment.
If they do not want to do this for you, find another dealer.
Jan 22, 2009 | Technics SL-1210 Turntable
Speacker problems
cheak sound card settinsg for 4 ch 5.1 output or in audio main menu ok
Feb 01, 2008 | Logitech X-530 Computer Speakers
Denon Avr-588 setup
dojran,
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
smeags
Jan 03, 2008 | Denon AVR588 Receiver
Boston Acoustics BA790 Computer Speakers Logo
227 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
