Question about Compaq Presario 700 470024-192 Notebook
Screen replacement I have replaced a screen before in another computer. I have the top screws out of benzel on this compaq c700 laptop, have the benzel pulled apart to the bottom, and now stuck. How do i finish removing it so I can get screen out and replace it, do i have to take off keyboard, and if so how?
  • pmtm05 Sep 27, 2008
    Thank you. Was having problems getting to all the screws I needed to so I could finish getting the screen out.
  • Anonymous Sep 29, 2008
    i need the drives of C 785 TU
    Problem Solver:
  • 11 Answers
Manual is available for this laptop at
It covers screen replacement
Posted on Sep 27, 2008
Fix black screen
Computer got you stressed?....................Life getting you down?...
Feel like if one more tiny problem comes up, you're just going to end it all?
.........GET OVER IT!
"$^&%^*&& HELP ME PLEASE #@%^&&^%^&*"
Don't ever come to this website, and post that again
Help me please?..................Yes
Moving on................
An external monitor works
Good. This way you know the problem is either the Video Cable, or inside the Display Assembly.
Video Cable:
With the Compaq Presario C700 series of Notebook PC's, the Video Cable connects to the motherboard; in an area under the Keyboard, and Switch Cover.
(Above the F4 key)
It then leads under the left Hinge, and up into the Display Assembly.
From there a small cable branches off, and connects to one side of the Screen Inverter.
The main part of the Video Cable, goes on to connect to the back of the LCD screen.
Example of Video Cable,
The large connector on the Right side, connects to the back of the LCD screen.
The smaller connector shown at Bottom connects to the motherboard.
The small cable leading up to the Top/Left, connects to the screen Inverter.
Just from repeated normal opening, and closing of the laptop; the Video Cable may become pinched, and pulled on. Sheath of Video Cable also hardens over time, and this also adds to the equation.
However, this laptop has been dropped. There's a real good chance of a problem with the Video Cable.
Pulling on it can lead to the connections coming loose.
Motherboard side, screen Inverter cable, and LCD screen side.
Procedure is to go through the various connections, and PHYSICALLY check them. Try to plug them in tighter.
Motherboard connection:
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Disconnect the Keyboard, HOWEVER do not disconnect the Keyboard Cable from the motherboard.
Once Keyboard is removed from Palm Rest Cover, take the LCD screen side, and roll the Keyboard over.
Bottom side up, lay on Palm Rest Cover.
3) Now remove the Switch Cover.
The Switch Cover is the wide strip of plastic, above the Keyboard, and below the Display Assembly.
The Switch Cover is just that........a Cover.
No wires attached.
Physically check motherboard connection.
Reinstall power. Turn laptop on.
No change?
Remove ALL power again.
LCD screen side connection and screen Inverter connection:
4) The plastic frame in front of the LCD screen, is the Display Bezel.
Remove it.
Right behind the Display Bezel, and mounted on the bottom/middle of the Screen Frame; is the screen Inverter.
Just physically check the screen Inverter connection, but go on to the LCD screen side connection.
The LCD screen is an assembly of layers. These layers are held in the factory set position, by a metal Screen Frame.
Resembles a picture frame.
Attached on either side of the Screen Frame, are Brackets.
The brackets are attached to the Hinges, and the whole assembly is just referred to as a Hinge.
There are screws that hold the Hinge brackets to the Screen Frame. There are also screws that hold the Screen Frame together.
Be SURE as to which screws you remove. You do not want to remove the Screen Frame screws.
Remove the screw that hold the Hinges to the Screen Frame.
Tilt the Top of the LCD screen forward towards you, and physically check the LCD screen side connection; of the Video Cable.
Lay the LCD screen back, put a screw in on each side, to temporarily hold the LCD screen in place.
Reinstall all power. Turn the laptop on.
Still no joy?
Remove the Video Cable.
The Video Cable needs to have a continuity test performed, with a multimeter set to OHM's. (1K)
Every wire in the Video Cable is checked.
No reading on a wire indicates a stretched/broken wire.
An assistant should also be used, to gently wiggle the Video Cable while checking.
An intermittent reading on the multimeter indicates a stretched/broken wire.
Or take the Video Cable down to the nearest small computer repair shop, and have the resident tech check it for continuity.
Should only be a coupla' bucks.
The Video Cable MUST be ruled out, before going on........
5) Video Cable checks out OK, or a replacement is used; and still no display on laptop's internal monitor, the screen Inverter is next in the diagnosis.
To test a screen Inverter requires a sensitive multimeter. Read fairly expensive,
Due to this, the ease of accessing to replace, and the usually low cost; the screen Inverter is just replaced.
6) If the new replacement screen Inverter brings no joy, then the problem is the LCD screen.
HP Support > Compaq Presario C700 series of Notebook PC > Manuals > Service Manual,
Scroll down, and click on -
HP G7000 Notebook PC and Compaq Presario C700 Notebook PC - Maintenance and Service Guide
At the top is the Adobe Reader page number box
Page 21 is the start of the Illustrated Parts Catalog.
The next page shows you an exploded drawing of the laptop.
Page 58 - Keyboard
Page 61 - Switch Cover
Page 63 - Display Assembly
The F700 HAS wires to the Switch Cover. The C700 does not.
Just posting to give you a hands on look, instead of just a Service Manual.
02:59 - Here you can see how I described LEAVING, the Keyboard Cable attached to the motherboard, and just rolling the Keyboard over onto the Palm Rest Cover.
In Spanish, but a 'Picture is worth a thousand words', they say,
Not the Presario C700, but shows in better detail on releasing the Lock Clips (Detents), at the Top of the Keyboard,
Specifically photos in Steps 9 through 11.
(You won't need an ESD wrist strap for this procedure. However if you have one, wear it by all means.
IF, you remove the Palm Rest Cover, then you better be wearing an ESD wrist strap; and have it's alligator clip attached to a good ground source )
Apr 06, 2013 | Compaq Presario 700 470024-192 Notebook
Lost my laptop presario c700 driver disk please allow me to download free
Hello there,
To be exact there are six models of Compaq C700 laptop. to identify the model, turn you laptop upside down and read the details on the sticker.
Compaq C700 Main Compaq C700 CTO Compaq C700 EM Compaq C700 ET Compaq C700 LA Compaq C700 CTO Compaq C700 XX
1. Select your OS 2. Scroll down, drivers are displayed alphabetically
Hopefully this helps. Thank you for posting..
Jul 08, 2011 | Computers & Internet
I need a screen for the lapta laptap for a compaq c 700
From a quick search on the internet,
Need the Service Manual? (Free)
Go down to the line that starts with Compaq Presario 1100, then go across to > C700, and click on it.
This is a PDF file. After you click on C700 you may not see anything happening for up to 30 seconds. The file is downloading in the background.
After you see the first page come up, I suggest you let the file download all the way before looking through it.
(Took 7 seconds for the first page to come up, and an additional 53 seconds for the file to fully download, just now.
I'm using a medium speed DSL connection)
Page 55 - Display assembly
1) Work on a table
2) Observe Anti-Static Precautions.
3) Use a multi-compartment container for the various screws you will remove.
Mark the compartments for the area the screw/s came out of.
Do NOT mix them up!
If no multi-compartment container is available, you can use a clean egg carton. Mark the egg holders.
4) When you remove the LCD screen, look at the back. Write down the manufacturer name, and part number. Match it up to the one you're going to buy. Make SURE it it is the correct size.
(The screen is measured diagonally. From corner to corner)
If the screen is dark, and there is no apparent physical damage to it, do not assume the problem is the LCD screen.
Laptop on use a flashlight to see if you can see faint images.
If so, 90 percent of the time the problem is a bad Inverter.
A small circuit board located at the bottom of the Display assembly, and behind the Bezel.
MUCH cheaper than an LCD screen.
If you need guidance in replacing the LCD screen, or Inverter, and would also like some tips, post in a Comment.
Nov 22, 2010 | Compaq Computers & Internet
How to remove the benzel when replacing the screen on a dv5-1002nr
try removing the screen rubbers (little dots o rubber on the bezel) beneath them is the screws. undo them
Mar 21, 2010 | Computers & Internet
Very dim screen on dv1000
Jul 04, 2009 | HP Pavilion dv1000 Notebook
Compaq presario c700 laptop
i want to all drivers for compaq presario C700 madel, please hurry uppppppppppppp
Aug 19, 2008 | Compaq Presario 700 470024-192 Notebook
Missing drive
Use system restore to set computer earlier date that was working fine. If there is a missing driver by symptoms please go to or
For further assistance please post more.
Good Luck
Jun 16, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
98 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
