Question about Apple iPod nano
Want to know how many songs ipod nano holds
Last disc in ipod would not execpt total tunes on ipod at the moment is 1,190
    Problem Solver:
  • 16 Answers
It would vary as its 4gb but depending the size of your mp3 or since your ripping from CD it'd probably be a high bit rate so more space could you not clear out some space?
4gb usually holds 1,000 songs based off a 4 minute interval
Posted on Nov 13, 2011
  • joan sawyer Nov 13, 2011
    thank you for answere it helped a lot.
    New Friend:
The ipod nano that is 4GB holds only about 1,200. a 2GB would Hold about Around 500 songs, but also depends on the song's length, bitrate, format, ect. For a 6GB not every song is the same size so there is no way to make an exact answer unless every song was the same size. But its around 5000. An 8GB holds about 2000 songs, but with the same price, you can get the 30Gb Video Ipod,
Posted on Nov 25, 2012
SOURCE:
How to load songs in ipod
Download itunes from http://www.apple.com/itunes/ once installed you can then either buy tunes from the itunes store or load up your CDs into itunes. Once you have songs in tunes connect your ipod nano to your computer and then under devices you can then control what tunes go on the ipod. Hope this helps.
Dec 11, 2011 | Apple iPod nano
Memory loss on ipod
The ipod nanos the smallest product in the Apple iPod line. The fourth generation Nano comes in two different capacities, each capable of holding thousands of songs.
    Capacities
  1. The fourth generation iPod Nano comes in 8 GB and 16 GB models. The 8 GB version can hold 2,000 songs, and the 16 GB version can hold 4,000 songs.
  2. Tips
  3. Song capacity estimates are based on music encoded in Apple's proprietary format at a standard, average bitrate. The higher the bitrate, the better the quality. Songs deviating from Apple's standard (for example, CD-quality music or high bitrate MP3s) will use more disk space.
  4. History
  5. Nano's predecessor, the iPod Mini, was released on January 6, 2004, and was available with a 4 GB hard drive. The Nano was first released on September 7, 2005, and was the first iPod to use flash memory. It was first available in 2 GB and 4 GB versions. The fourth generation Nano was released on September 9, 2008.
  6. Size
  7. The fourth generation iPod Nano is 3.6" tall and 1.5" wide.
  8. Video
  9. The third generation Nano, released on September 5, 2007, was the first Nano to feature video playback. Storing videos on Nano can dramatically reduce the amount of songs it can hold.
Nov 24, 2009 | Apple iPod nano
My ipod nano isnt playing any songs
acc or mp3 format i tunes can help maby just a ges
Jul 02, 2009 | Apple iPod nano 3rd Generation
My i-pod nano (2GB) will not hold more than 43 songs when I import from my cd's. My ipod is clear of all songs and so is my library. Are I not suppose to have at least a 500 song capacity?
I have an I-pod nano 4 gb. What I think is going on is you are loading full "wav" files. The 500 songs is predicated on low quality "mp3" songs. Normally, I-tunes will convert the "wav" file to an "mp3" file.
Check your music files on your computer and assure they are "mp3" files. If they are make sure your I-pod does not have other "stuff" on it. Use I-tunes to reset it an "like-new" condition (that removes all files)., then use I-tunes to re-install your music.
If you are downloading files from the I-tunes store make sure they are safe so you do not loose your investment in tunes.
Since they are from cd's make sure the ripped files are safe, then try a re-install.
Should work.
Cheers
Mar 30, 2009 | Apple iPod nano
Ipod wont play and games are gone
Try reseting the ipod.. Follow the steps and let me know the status
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Feb 15, 2009 | Apple iPod nano
Ipod nano can't read or play songs
Did you use iTunes to put the songs on? This is totally essential to being able to see the songs on your iPod. download iTunes here
Oct 24, 2008 | Apple iPod nano 3rd Generation
Ipod nano can not play songs from beginning
It droped once (it wasnt a serious drop) a month ago. After that drop it worked well. Problem occured after last sync a week ago.
Jul 24, 2008 | Apple iPod nano 3rd Generation
Frozen iPod Nano
Press and hold the center button while holding down the menu button. This will reboot your Ipod. Check your IPod cable to see if its shorted. If might have transferred a song and crash in the middle of the transfer.
Jun 22, 2008 | Apple iPod nano
How many songs?
The iPod nano, introduced September 7, 2005, can hold approximately 500 or 1000 songs (on the 2.0 GB and 4.0 GB versions respectively in 128-Kbps AAC format) and as many as 25,000 "iPod nano-viewable" photographs.
Oct 02, 2005 | Apple iPod nano
How many songs can the iPod hold? nano?
Sep 29, 2005 | Apple iPod nano
Apple iPod nano Logo
243 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
