Question about Krups XP7230 Compact Super Automatic Espresso Machine
Krups Espresseria Automic XP7200 coffee machine
I have just purchased a krups espresseria automatic XP7200 coffee maching and followed the instructions carefully.I cannot proceed as the menu says "Put the cake container back". What is the cake container? I have turned off the power and tried to reset the machine but keep on getting the above message. Can you help me please?
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
Posted on Sep 27, 2008
Smonet is rght and on this machine the cake container is on the left side (when standing in front of the machine). how about reading the manual ???
Posted on Oct 24, 2008
Krups Espresseria Automatic Premium machine repeatedly displays the following message "Filling of machine necessary".
You may find that whatever detects the water level is faulty. Normally there will be a magnet that floats in the side/back of the tank. If it's sitting on the bottom of the tank then try and shove something plastic between it and the bottom of the tank to lift it up. If that fixes it then you have a choice to leave it like that or buy a new tank.
Feb 08, 2017 | Krups Coffee Makers & Espresso Machines
Machine is dead. Is there a fuse somewhere? Krups Espresseria.
There is no easily replaceable fuse unless you are from somewhere like the UK where they have a fuse in their giant wall plug on the end of the cable. Some of those Espresserias had a switch button fault where part of the button can break and the button will no longer activate the switch.
Apr 27, 2015 | Krups Coffee Makers & Espresso Machines
ERROR CODE E09 TO EA82
There is a problem with the heating of the thermoblock, it will require dismantling to check.
Feb 24, 2015 | Krups EA8250001 Espresseria Full Automatic...
How to stopp the leaking under the watertank?
Normally solved by replacing the tank seal where the tank plugs in.
Aug 30, 2014 | Krups EA8250001 Espresseria Full Automatic...
What do I do when coffee beans not getting to grinder
They cannot "not get to" the grinder, the hopper is mounted directly above the grinding teeth. The grinder is probably blocked and you will need to remover the housings and take out the grinder for cleaning and inspection. Most common cause of grinder blockage is dampness inside the housings from a leak somewhere inside the machine.
Jul 21, 2014 | Krups EA8250001 Espresseria Full Automatic...
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
Krups xp7420 espresseria automatic
am o proare 01 la un espesor krups 7220/7240
May 11, 2008 | Krups Coffee Makers & Espresso Machines
Krups XP7230 Compact Super Automatic Espresso Machine Logo
2,259 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
