Question about Philips GOGEAR SA6045 MP3 Player
When i charge it it turns white after that it shows a problem of......
Connect to PC and used device manager to repair!
  • Anonymous Sep 30, 2008
    when i charge it it shows a battery then turns off
  • 8,596 Answers
Run the Repair tab in the Philips Device Manager that came on the installation CD
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Says philips than turn off
Hi maliksmalls,
I would attempt a Repair/Recovery, which will restore your device to factory settings as well as update the firmware and improve functionality of your player.
You can find a lot of valuable information on the Philips Support Site: http://ow.ly/6j8hW
After performing the Repair, allow your player to charge for several hours and be sure to practice a regular charging routine. If you have any additional questions, you can chat at the above link or you can reach Consumer Care at 1-888-744-5477.
Hope this helps! If so, let me know by rating this solution. Thanks!
REPAIR INSTRUCTIONS:
Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software.
NOTE: Contents will be removed by using the repair function.
1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table:
Aug 27, 2011 | Philips GoGear SA3125/37 MP3 Player
So my philips mp2 sa2315 would usually turn off every once in a while i would switch a song.That wasnt a big problem i would just turn it back on and go back to what i was doing.But recently now when i...
Hi mizzdramapri,
I would attempt a Repair, which will update the firmware and restore the unit to factory settings.
For more information on this product, including FAQ's and manuals, visit: http://ow.ly/6j8Gd.
Hope this helps - if so, let me know by rating this solution!
Here are instructions for the Repair:
IMPORTANT: Please back up data in the player before performing a repair.
  1. When your player is locked up or seems dead, you may connect to your PC to repair the device with the Device Manager.
  2. Launch Philips Device Manager at Start > Programs > Philips Digital Audio Player > SA2xxx > Philips SA2xxx Device Manager on your PC.
  3. Connect your player to the PC.
  4. Device Manager should acknowledge your player and automatically go into recovery mode.
  5. Follow the instructions given by Device Manager to proceed.
  6. After the player has been repaired, click OK and disconnect your PC.
  7. The player is ready for use again after restart.
Aug 27, 2011 | Philips SA2315 MP3 Player
My Mp3 player was not starting. while connected to PC or not
Hi jai mosl,
You may want to consider performing a Repair in order to return your player to factory settings, improve functionality, and update the firmware. Afterwards, be sure to charge for several hours and practice a regular charging routine.
If you are still experiencing issues, you can find FAQ's, software, and manuals at:
http://ow.ly/64mxe
Consumer Care can be reached at 1-888-744-5477 if you need additional assistance.
Hope this helps! Let me know by rating this solution. Thank you.
Aug 16, 2011 | Philips SA2315 MP3 Player
My Philips GoGear Aria (8GB) Doesn't turn on
Hi poseidonisco,
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA3125/37&slg=en&scy=US
You can find the recovery key on your player from the below table.
Aug 07, 2011 | Philips SA3125\02 MP3 Player
Hi. i am tryinmg to charge my nieces mp3 that she has got. she lost the original chatger (lead) so i am using a spare one that i have found.. its coming up on the screen connected but its not showing the...
Hi, why it's not charging yet ,i think its not yet recognizing the mp3 player yet. You will need to follow the below step and solve the problem.,Then after trying out this steps and still does not work,That means you will need to replace the USB cable...
Hi, when an m3player does not detect on your PC, usually when Drivers that corrupted..
How to rectify the problem:
Connect the mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 player Connect and mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for mp3 Players when used with Windows OS.
The mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Good luck......
Mar 12, 2011 | Audio Players & Recorders
Sansa Fuze, 8GB, unable to be turned on in the car after playing it just a short while ago, and is unable to connect to computer; screen is white.
You may need to now reset the player, that may have been a bit much for it. To reset your Sansa Mp3 player. Slide and hold the Power switch up for approximately 20 seconds. Release the Power switch. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present.
http://www.fixya.com/support/r3962743-sansa_mp3_player_frozen_reset_format
-Also try to refresh the driver in your PC. Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. >>>><<<Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
The mp4 player keeps crashing my computer
If your PC is running Windows Vista, don't even think about conencting it until you get the firmware upgrade for the device.
Triple Reset for GoGear:
-Tha Mp3 Doctor
Jun 08, 2008 | Philips SA3125\02 MP3 Player
Mp3 player
please help my player to work again
Jun 05, 2008 | Philips GoGear HDD6330 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
29 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
