Question about Nikon AF-D 80-200mm f/4.5-5.6 Lens
Lense not working
I have a Nikon D70's and just purchased a used Nikon 80-200 mm D telephoto ,when I turn the camera on (manual setting) I get EE in the viewfinder and cannot take a picture also the auto focus does not seem to work? Any suggestions the lense came with no written info.
   Thanks Rewind
  • gmayert08 Jan 08, 2009
    Yes that is the answer,Thanks
                                 Rewind
  • 146 Answers
Have you turned the lens aperture ring to the lowest value (32) and locked it with the little button thing?
Sorry if you know about this.
Posted on Jan 06, 2009
Need to convert a Vivitar 70-150mm telephoto from Canon TX to Nikon FTn mounts
Vivitar made several different 70-150mm lenses. If the lens has a T-mount then you can purchase a Nikon T-mount adapter and replace the Canon one on the lens. If the lens does not have a T-mount then you're out of luck. Nikon cameras have thicker bodies than Canon cameras, and an adapter would have to have negative physical size.
Mar 16, 2014 | Vivitar Series-1 3.5x Tele Conversion...
Nikon d300s
As the name states, this is a manual focus lens. As such, it does not have autofocus capabilities.
Jul 29, 2013 | Contax Telephoto 85mm f/1.4 Carl Zeiss...
I am putting the sigma 500mm lense on my nikon d90 camera and i am getting a double ee error
Turn the aperture ring to its smallest opening (largest f/number). You can control the aperture from the camera body, the same way you do so on a lens without an aperture ring.
Jul 08, 2011 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
I also have recently purchased a Rokinon 500-1000 mm telephoto lens with the 2x multiplier, however, when I attach it to my Nikon D3000 the camera still says "lens not attached" Is there...
The Rokinon lens does not have the electronics to communicate with the camera. You must set the camera to the Manual exposure mode in order to use this lens. You control the shutter speed on the camera and the aperture by turning the ring on the lens. You also will not be able to use the camera's exposure meter; you can use the LCD display and the histogram to fine-tune the exposure.
Refer to the manual for full details on using the Manual exposure mode.
Jan 26, 2011 | Rokinon 500mm f80 for Nikon
I can get my 50mm lens to work with my d70 nikon.
If the lens has an aperture ring, make sure it is set on the largest f number. Make sure the lens is mounted fully on camera. Oherwise an AF 50mmm f1.8 lens should work on a D70 with no problem
Oct 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
I'd like to purchase a micro lens for my Nikon camera. My question is: Does the Phoenix AF 100mm f/3 5 Macro Telephoto Lens used with Nikon D 90''
If the Phoenix lens is autofocus (AF) in Nikon mount, it will work with the D90. You may find that you want to switch to manual focus when you are using it for macro shots for better control of focus. It will still set exposure properly when set to manual focus.
Apr 03, 2009 | Cameras
Purchase Zoom Lenses
Canon currently makes super Telephoto lenses from 300mm to 800mm and a number of zoom Telephoto lenses from 28-300 to 100-400. You can also special order a 1200mm lens from Canon at a cost of $99k! (There are only about 20 such lenses made so far.)
You can also get a 1.4 or 2x teleconverter to further increase the power of a telephoto lens. However, the cameras are unable to auto-focus when the minimum f-stop exceeds f/8, which can happen when you use one (or both) of the teleconverters on these longer lenses, so you have to manually focus the lens.
You can also get telephoto lenses from other manufacturers such as Tamron and Sigma that are built to work with Canon cameras. However, the Canon lenses are generally regarded as the best quality.
Dec 21, 2008 | Nikon D70s Digital Camera
How do i set my nikon d70 to work on a vivatar flash
What Vivitar Flash? If an older model with only pc cord connection, you will need a Nikon AS-15 adapter. But you must also reaalize that if the firing voltage is more than 500volts, this may and possibly will screw up the camera if not the flash circuitry. Better off safe witha WEIN SAFE SYNCH HOT SHOE TO PC ADAPTER. Mounts to hot shoe on camera and allows pc connection cord to flash.
Dec 11, 2008 | Nikon Telephoto - Rear Lens Unit ONLY -...
Auto focusing problem
Your camera is only compatable with AFS-type lenses because it has no screw-drive motor.  You can only use AFS Nikkors and Sigma HSM lenses (the lens actually has a motor inside).  You were misinformed.  Bring the lens back and ask for a refund. Take that money and purchase a compatable lens somewhere else.
Sep 22, 2007 | Quantaray 500mm/1000mm Preset Telephoto...
Sigma 170-500mm APO lens on Nikon D50 won't autofocus or shoot
When you get a flashing EE, it means there is an Eror somewhere. Most cameras have a botton you press to reset it. Usually it is the battery check button. Try that. Also try taking the lens off the camera, unlocking the aperture ring, remount the lens and then lock the aprture ring to the minimum F stop. I think this should solve the problem.
Aug 06, 2007 | Sigma APO 170-500mm f/5-6.3 DG for Minolta...
Nikon AF-D 80-200mm f/4.5-5.6 Lens Logo
167 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
