Question about Akai PT5492S 54" Rear Projection Television
PT5598hdi This morning there was a click while watching tv and I suddenly had ghosting, bow tie effect and 2 stripes of color on each side. Looking at the site I figued it was the convergence ICs. Took out the board and still had the same effect. I had 2 new ICs replaced and brought the board home. Put the board in and only had sound. The screen is blank. Turned the tv off and unplugged it. Plugged it back in and now I have just blinking of the red light between 7-10 times and then nothing. Last year I also had the board and power supply replaced. I just spent the last bit of money I have! Great huh. Just my luck. Is there anything I could try now. Thank you kindly for your time all of the sudden I have the same type of problem I think. looks like everything is in 3D. the bowtie effect is going on. I really can't afford to have this fixed. What should I do. Is it just some type of setting or should I just trash the damn thing?
  • Akai Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,PioneerPT5598hdi - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix here http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
    Sergeant:
    Champion:
  • 431 Answers
If its shorting out your conv. ics you need to ck for a shorted yoke
Posted on Jun 18, 2010
SOURCE:
How do i fix my samsung 1080i hdtv. It has a double picture and is red and blue, and also looks like a bow tie effect
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved pictures convergence problems.The shop,will cost u like $300-$350 for parts and labors.
Nov 21, 2010 | JVC AV-48WP74 48" Rear Projection...
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
Jan 25, 2008 | Televison & Video
AKAI PT5598HDI Colors out of line and picture is bowed in on bottom and top.
http://www.fixya.com/support/t1663670-akai_samsung_pt4299hd_convergence Adjust the convergence manually. It's a pain and takes alot of patience. The diagram for the remote buttons helps a lot. If it won't adjust you'll have to replace a part inside the tv. Good luck! Hopefully it'll adjust.
Jun 14, 2009 | Akai PT5598HD 55" Rear Projection...
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
All the sudden pitcher is bowed and colors are sepertated
This is convergence. First read FL231 fuse problem in tips and trick section to see if this may be the problem
Jan 22, 2009 | RCA HD52W58 52" TV
Watching TV and top 1/3 screen ghosted by colors
on this type of tv each gun is controled by hor.and ver. chip together. it is on the board that controls the convergence of the tv. some manufactors have recalls on problems like this. i dont know if this one does but it may. you can check with mitsub. i do know that this part is about 250.00
Jan 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 10, 2007 | Samsung PCL6215R 62" Rear Projection...
Tv needs fixing, advice appreciated
it would intermittedly display a bowed rainbow effect and the picture would jump to that/black/back into focus. it was nothing but due to change of place due to decaussing ckt to take care of magnetic effect of earth. this morning i turned it on with a black screen. It has audio but no video. your problem it sounds me that it is due to loose contact or loose connector or due to video ckt. as you said that sudio is ok. if you are not tech person call skilled tech to fix it .it is not a major problem. hope this will help you please let me know what happened.
Sep 29, 2007 | Toshiba TP50F60/61 TV
The convergence ICs probably have a cracked solder joint on the foil side of the circuit board. Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. To fix this yourself, you will need to be able to identify the two convergence ICs, have a basic knowledge of electronics and be able to use a soldering iron. You will also have to do an alignment through the service menu.
Apr 01, 2007 | Samsung HC-P4752W 47" Rear Projection...
Akai PT5492S 54" Rear Projection Television Logo
1,461 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
