Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Flash not working
The orange light comes on but no flash when the shutter is pressed all the way down.
Flash not working . All other Modes/ functions work.
  • paigekillian Oct 21, 2008
    My canon SD550 was working fine and then all of a sudden it stopped taking pictures with the flash. When a flash is required and I push down the shutter button, the orange light comes on, but nothing happens. The lightening bolt flash symbol flashes on the display but no picture is taken. How to fix?
  • 489 Answers
Hi
Either your flash is defective and to solve the problem you replace the flash; or if that doesn't work you will have to replace the mainboard (PCB). Its very hard to say which will solve the problem as you can't tell before you try.
The other option is to buy a defective camera online and make one good camera from the two.
The flash costs about $30 (I would have to check pricing), and we can install it for you if you need it done; we are a digital camera repair business and are happy to help. (Google: Darntoothysam com)
Just remember if you're working with the flash to be careful, you will a good healthy ZAP! if you touch both flash terminals at the same time. =)
Hope this helps, let me know if we can help with anything.
Good luck from Darntoothysam com
Thomas
Posted on Oct 18, 2008
Camera wont snap picture
As long as the orange light is on, the camera is not ready to make a picture. The focus area, should become green, to tell you the camera is in focus. Then you can press the shutter release button complete. Check the settings of the camera, and put it in automatic. When you put it in one of the manual modes pipe P M S or A, the camera will not take a picture when there is not enough lift or something else you did not take in account.
If the camera keeps this way, unless you switched to auto, it could be there is something going on. but let me know it auto des not work.
Jan 27, 2014 | Nikon COOLPIX L810
My sony cyber-shot DSC-H10 flash stopped working. The flash pops up like it is going to work, but does not flash. I can take pictures but with noflash. Can you help me?
You flash is in ' Flash forced OFF ' position.Press on the flash control button repeatedly until one of the four modes are selected.
1.Flash Auto - Flashes when there is insufficient light or backlight ( Default Setting )
2.Flash forced on
3.Slow synchro - The shutter speed is slow in a dark place to clearly shoot the background that is out of flash light.
4.Flash forced off - ( Your current mode ).The flash automatically pops up and strobes when using the flash.Close the flash by hand after use.
Jun 03, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
How do you turn the flash on
Using the Flash
The flash is designed to function automatically when lighting conditions permit the use of flash.
The camera has 3 flash modes: Off, Auto , and Always On. You can take an image using
a desired flash mode to suit your circumstances. The flash's effective range is
35.4” ~ 59.1”(0.9m~1.5m) (in Normal mode).
The flash is disabled if the camera is set to Macro mode.
1. Press the Power button to turn the camera on.
2. Toggle until your desired flash mode appears on the LCD display.
3. Compose your scene and press the SHUTTER button
to capture your image.
Flash button is the one like an arrow pointing downwards. (not a straight arrow) Usually located beside Disp, OK, Menu.
Apr 03, 2010 | Polaroid A500 Digital Camera
Flash buttom cannot be pressed to take a picture....turning the camera off and then back on helps...so does pointing downward and pushing button 1/2 down, and then snapping picture.
the mode that the camera is in, probably auto, is saying that there is enough light. when you point it down it reduces the light and when you press the shutter down half way it sees the light deficit and pops out the flash. i would say to play with the modes and preset modes.
Jun 16, 2009 | Nikon D60 Digital Camera
When shutter depressed "AF" and "SB" LED's flash
My camera's shutter will not depress all the way due to a red flash light coming up all the time in the Flash-Ready indicator lamp (refer to pag 28 in the Nikon manual). It can be full sun outside but it will not work due to the red flash light coming on.
A work around is to select a flash mode of 'cancel'.
There is a button toward the front of your camera called the flash mode button. Click that until you see strike mark on the flash icon of your monitor screen (see page 32 in the Nikon manual).
The camera must have a malfunction of determining the lighting so it always thinks you need to have a flash on the picture. Of course this is not 'fixing' the flash/lighting issue but you can take typical day pictures for now with this work around.
Dec 17, 2008 | Nikon Coolpix 5400 Digital Camera
Operator Error Canon i850 printer
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
Red dye reduction
You can find your manual here....www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
AUTO FLASH:
Automatically fires in low-light and backlight conditions.
RED EYE REDUCTION FLASH:
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
camera.
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
Sep 30, 2008 | Olympus Camedia C-725 Digital Camera
Flash not working properly
Try setting the shutter speed to 60. The 2000 has 3 different modes. 2 auto and 1 manual. In manual mode the flash is at full power. In the 2 auto modes the flash meters the available light and sets the power. There should be a table on the back that tells you what to set the appeture at based on distance and film speed. On the AE-1 you will have to set the shutter and appeture yourself. It won't work auto like a Canon speedlight will.
Sep 04, 2008 | Vivitar 2000 Flash
Canon XTi Built in Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Picture too light
The cause and solution may include one of the following: The flash is not needed. Change to Flash Off or decrease the flash compensation in any of the PASMC modes (certain cameras only). The subject was too close for flash. Move so that the distance between you and the subject is within the effective flash range. There is too much light. Decrease the exposure compensation. If you use flash, adjust the flash compensation in any of the PASMC modes (certain cameras only). Auto-exposure was not set. Press the shutter button halfway and hold. When the AF/AE indicator turns green, press the shutter button completely down to take the picture (most cameras).
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
101 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
