Sony HT-SF2300 home theatre system. I have this home theatre system and it doesn't seem to play the rear speakers when in r.f.d. auto,dolby pl,pl ii mv,pl m5,concert,stadium,sports,hall,portable,jazz and so on... Is there a way I'm supposed to program the stadium, sports, hall etc...? I can't understand why the rear speakers only work in multi st. Please note this is my first theatre system. I know hardly anything about recievers.
SOURCE: samsung ht-z310 home cinema no sound rear speakers
I seen the same thing when I first opened mine except my "center" speaker wan't working. It had to do with the "Mode" it was in. The Mode button at the botoom of the remote changes the speaker configuration.
There is also an option in the setup that allows you to turn on/off speakers for the system, all of mine were either Present or Small which enables them to work.
Posted on Aug 11, 2008
nick_helpap
  • 334 Answers
SOURCE: Can't hear the voices on my home samsung HT-X70 home theatre system
u stoip movie start it use prologic make sure center speaker pluged in ect
Posted on Oct 08, 2008
SOURCE: Onkyo digital reciever has poping noise when in dolby sound
I have the same reciever, and had the same problem.  Contact Onkyo, this is a known issue where defective DSP chips were used and manifest problems with a popping / clicking sound when using surround settings.  These receivers also have a Dolby Digital input issue that can cause audio dropouts when watching cable or SAT broadcasts that encode DD using a 'newer' broadcast encoding methods.  Onkyo is covering the cost of that repair for me now, even though the receiver is 5 years old now....
Posted on Mar 06, 2009
SOURCE: rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Posted on Apr 14, 2009
SOURCE: Prima HT 8104 home theatre
in the 3D processing turn on the Pro Logic and the for the mode as well set it to pro logic.
it simulates 5.1 surround.
this is what I did and it's decent. Other way would be to run the system through a amp/receiver that supports 5.1 surround.
Posted on Apr 27, 2009
DAV-DZ777 no longer plays TV sound through home theatre. DVD, radio etc still works...
The hdmi needs to be ARC compatible and connected to the HDMI connected labled Arc.
Sep 10, 2016 | Sony Home Theater: DAV-DZ777 CODE FREE...
Code to change settings for Small loud speakers to large. Model No HT-F450K to HT-F455K models
Speaker size selection usually is part of receiver set up; the DVD player has nothing to do with it.
Jun 27, 2016 | Samsung HT-C650W DVD Home Theater System,...
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Could you please tell what cables & wires come with the sony home theatre system ht-ddw1500 even a picture of the cables/wires will be great.
Two good documents are here in English/Spanish under "Manuales":
http://esupport.sony.com/LA/perl/model-documents.pl?mdl=HTDDW1500
Neither one lists any included wires or cables. Any external devices you wish to attach will usually come with the required cabling. The rest is just plain old speaker wire for the speakers.
Jan 23, 2011 | Sony HTDDW1500 Theater System
How can I connect my PS3 to the HT BD2 and get it to play dolby digital or dts audio? Thanks
Use an optical cable and then it should work just fine. Just saw Avatar from my PS3 through the Samsung HT-BD2 and the sound was excellent.
So go and buy an optical cable :)
My problem is to get the BD2 to download updates. It doesn´t seem to work for me.
Apr 12, 2010 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Connected Samsung Home theatre HT-Z320 to my new sony lcd. No sound, can anyone help
Check connections.
Make sure you are on the correct Input/Source, adjust volume acordingly.
Please give details about what sources and connections you are using.
Dec 27, 2009 | Samsung HT-Q100 System
Samsung HT Z320 sub and center speakers dont work
Set the system to the FM receiver/ Tuner Option. Select the 'mode" button on the remote control. Set the system to the Dolby PL II option. This will engage all the speakers. I had the same issue and this fixed the problem!
Jun 19, 2009 | Audio Players & Recorders
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Rear check message on HT-TXQ120 samsung home theatre
Nov 19, 2008 | Samsung HT-TXQ120 Home Theater System...
The rear speakers and the center channel speaker do not work
Hi, maybe,like my HT-THX25, my book states that sound will only be heard from the rear speakers when in DVD 5.1 or Dolby Pro Logic 11 mode, peronally I would love to hear sound from any of my speakers when TV is on lol. Geoff
Mar 23, 2008 | Samsung HT-X40 System
215 people viewed this question
 Grubhead
Grubhead
