Question about Intel Motherboard
System not Booting
Hi, When i switch on my system, i can go to BIOS (F2) and Boot menu (F12) but i cant boot after that options, because the moniter shows the blank screen.. Please give some solution for this issue..
XCFZD
Posted on Sep 27, 2008
Toshiba boot screen won't appear when turned on
It will help if you mention the Toshiba model so we can ascertain which BIOS is running. But in general, take the USB out of the slot, and then when the machine starts up, press F2 when you see the prompt.
Alternatively if you do not see the prompt screen, press the ESC key for 3 seconds immediatley as you start the machine and then F1- that should present you with the Setup screen
Feb 13, 2014 | Toshiba Satellite L855D-S5220 Laptop
Belta notebook usb/network booting windows system?
When you press the power button normally the boot options will display on the screen. Most times it is the F12 key to select the boot option. This is a temporary change only good for the current boot cycle.
Also most times the F2 key will get you into the Bios or System Setup where you can change the boot option and make it a permanent change.
Apr 29, 2012 | Computers & Internet
HP dx6120 wont boot from cd rom and I want to install windows in a new haerd drive. Is this a bios problem? How do I deal with it.
Possibly a bios problem if the bios is not set to boot from a cd/dvd.
Press Delete key or F2 as soon as you switch on, or whichever key it needs to get in to the bios. Change the boot option to boot from CD/DVD first. Save settings and exit.
Some computers have a one time boot menu which lets you boot from whichever drive you like just for that time. Usually F11, F12, F2.
Jan 28, 2012 | HP Computers & Internet
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format...
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
When i press power on; F2 set up and F12 boot options appear and nothing else happens and i dont know what to press next for ti to start up.
Are you trying to reinstall your OS? Or just trying to boot to normal mode?
If the first is your case, you have to choose booting with CD drive in order for your system to boot on your CD Installer.
However, if the second is your case, you don't need to press F2 and F12 after powering on. If you encounter this without your BIOS changed, try reverting it back to BOOT on HARD DRIVE. That is when you are in the BOOT OPTIONS, select HARD DRIVE and press ENTER.
Jun 24, 2011 | Dell Computers & Internet
How do I access the screen that shows BIOS options as I wish to upload UBUNTU 11.04 from a pendrive, so I want to make my first and possibly second BIOS options to be for the pendrive.
At boot time repeatedly pressing either, F2 , F12, or possibly Fn+F1 this is depending upon the bios wether it has been updated or upgraded. One of these should do the trick.....
May 15, 2011 | Dell Latitude CPI-A Notebook
I want to boot from usb flash drive. how can i do ?
Hi
Thank you for your query
Please try the following
1) Switch on PC
2) Press F12, del or the ESC key to enter setup
3) Go to advanced options and then choose boot options
4) In boot options choose USB peripheral to be set as first boot device
5) Save and exit from the BIOS screen
As the PC restarts make sure the USB flash drive is plugged into the PC
I hope this has been useful
Mar 12, 2010 | Biostar M7VKA Motherboard
SYSTEM SWITCHES ON AND DETECTS ALL THE HARDWARE BUT WONT GIVE ME THE "PRESS ANY KEY TO BOOT FROM CD-ROM OPTION"
Some computers allow you to select an alternate boot device by pressing the F12 key as you boot up.
If your computer doesn't have this option then go into the BIOS configuration and change the boot order and make the CD-ROM the first boot device and the hard drive the second boot device.
Aug 14, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
My computer keep on restaritng again ang again....
1st boot to BIOS (F2 at boot) see if system reboots there. If not, the try booting to f12 menu and run diagnostics.
Generally, things like partition corruption, bad RAM and viruses cause uncommanded reboots.
Jul 06, 2009 | Dell Inspiron 1525 Notebook
Which key to press at startup to gain access to BIOS E2180 Intel
There are a number of keys used to access the system BIOS at startup. F2 is probably the most common, but I see you've already tried that. I've also seen the ESC and DEL keys used, so try those. If that doesn't work, start working your way across the F1-F12 keys.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 13, 2009 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
