Question about Linksys Wireless-G Broadband Router
I bought my router in May of this year and it just quit working .
I had my cable guy to come out cause my computers were not working and he said that my router was fried
  • phalishas Jan 20, 2009
    my router just quit working all the sudden also
    Problem Solver:
  • 18 Answers
On the back of the router there is a small hole, it's the reset switch insert a pen or similar object in the opening and hold it down for 15 seconds this will reset the router to the original default settings. If this does not work maybe it is fried! But check ALL your cables and connections as well I've had cat5 cables go bad out of the blue , replaced them and I was good to go again! How long have you had the router? Is it still under warranty?
Posted on Sep 27, 2008
Where do i hook up my x box 2 the computer
It's quite simple actually. All you need to do, is buy one eithernet cable and have a router. (continued below)
Step 1. If it's an Xbox 360 it would've come with one ethernet cord. If it's an original Xbox, then you'll need to buy 2 instead of the intended 1.
Step 2. Make sure the ethernet cable from your modem is in the back plugged into the router, also make sure that another cable is plugged into the back of your computer and also to the back of your router (thats what one of the cables is for).
Step 3. Now take the second cable (the one that you bought) or the cable came with the xbox system and plug that into the back of your system into the ethernet slot.
Step 4. Plug the cable you just plugged into your system into a third open slot on the back of the router and Voila! you are ready to "Pwn The Noobs" on a 'lil XBL. Mind you that Xbox Live does cost money ($50 or so a year). Now you can play with friends, transfer pictures or movies or music, depending on if its an original or xbox 360!...I hope this helps
~Mr. Lonely~
p.s. - You will need to do a few more things: go to system setup on the xbox dashboard (all the way to the right on the screen where your profiles are kept) then go to computer setup. Then you will get a code to enter at www.xbox.com/pcsetup
The above will only hook up the Xbox 360 console to the INTERNET by routing the internet to it, a router just splits the internet and assigns internal IP addresses in order to allow internet use by both the computer and the Xbox console. If you meant how to hook up the console to "Browse" its hard-drive/DVD drive/etc., it is not quite as easy. You should look up "Xbox 360 hotswapping" in google or something and that will show you how to view the hard drive contents.
Have a nice day and do not forget to rate please...!
Dec 24, 2010 | Computers & Internet
Unable to access internet through DLink DI-524 wireless modem
I would suggest downloading the manual and check the settings for your country.. it can be found here.
http://support.dlink.com/emulators/di524_revc/h_lan.html
Oct 25, 2017 | D-Link DI 514 Wireless Router (DI-514)
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
How to encrypt router
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Mar 02, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
Router quite working. Wireless does not work nor
Follow this procedure :
  1. Turn off all components on your network - computer, router, modem, printers and any wifi laptops
  2. With the ethernet cable connected only between the modem and the router TURN THE POWER TO THE ROUTER ON and let it boot up.
  3. Turn on the modem and let it boot up to all lights on.
  4. Connect / boot up any and all other components on your network.
Keep this order handy in case of a power outage. Best of successes!
Dec 04, 2009 | Linksys WRT160N Wireless Router
Linksys WRT160N V3 Firewall issues
You need to check first if it is the program that is causing this or not. If you have a computer without the program, have it connected to the router. If it connects it may be the program. Check if switching cable may help. IT may be a faulty cable. It may also be something in your PC that is causing this one.
Aug 08, 2009 | Linksys Wireless-G WRT54GS Router...
Tried to install, would not work when hardwired. Works wireless
hii
As you telling that you bought this router yesterday, you unlimited tech support for 1 year from linksys - the direct number is 1800-326-7114
---i am tech guys are able to resolve your issue
Mar 16, 2009 | Linksys WRT160N Wireless Router
I bought a new desk, so i had to redo my internet, because it quit working on main computer when i hooked my computer back up, so i had to call my internet provider and i got main computer back up, and now...
you may need to reset router to factory settings. look in documents or their website for instructions that apply to your router.
Also, I assume you have everything powered off when switching cables.
Jan 02, 2009 | Computers & Internet
PROBLEMS SYNCING MY ROUTER TO MY XBOX. PLEASE HELP!
Ok plug everything in and Reset the router and modem wait a few minutes and try again.
Verify that that DATA cable at the Xbox's location works with a PC could be a simple bad data jack or patch cord. Do you get a connection failure like this? MTU failure?
The MTU(Maximum Transmission Unit) failure when testing the xbox's connection can be do to a few things because Xbox live requires a minimum MTU setting of 1364. Sharing a slower internet connection with other PC's in the house can cause this error, The incorrect MTU setting in your routers programming can cause this error, The lack of firmware updates to your router can cause this error, an older modem from your service provider can cause this. Old or worn network cables and jacks and or RG(coax) cables if you have cable internet could cause this. Your Router or gateway could be incompatible with Xbox live.
Try a direct connection to the Xbox without a router and reset your modem before doing it. If your able to connect then you know its the router. If not you know its the modem or cables or jacks or even your Xbox if you havent tested it elsewhere.
You can tell your ISP to mail you the newest updated modem... sometimes they will have a guy just drop one off.
This is trial and error.
May 08, 2008 | NetGear RangeMax WPN824 Wireless Router...
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
