Question about Hotpoint 23 in. BF41 Built-in Dishwasher
Dishwashing liquid was placed in the jetdry compartment
My son put dishwashing liquid in the jetdry area. The dishwasher overflowed with excess water and soap bubbles. What can be done? Is my dishwasher ruined?
  • ccarson004 Sep 27, 2008
    Thanks, I will try it and let you know. I am sure it will do the job.
  • 943 Answers
Hi thanks for the question no its not ruined . just keep filling using vinegar , that will cut down the suds .do it 3 or 4 times problem will go away thanks the appliance doc
Posted on Sep 27, 2008
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Dishwasher showing wrench symbol after using dishwashing liquid
I am assuming this F1 error is coming in only one drawer and that you are able to run the second drawer as normal.
In the case of your dishwasher the F1 error occured because the foam would have overflowed over the drawer top into the base of the unit. This would have triggered a flood switch which is there to protect water damage to the dishwasher. You can either wait a few more days until the base of the dishwasher drawer unit dries up or you can dry it yourself.
To dry the base, extend the drawer as far out as possible (turn mains power off first). The use a few towels and push them on to the base. Pull the towels out and dry the base especially the centre of it with a hair dryer.
The F1 should disappear once you put power back on .
Hope this helps. You have a very helful child who sets the dishwasher up. I have to keep pushing my children to even empty it.
Jun 04, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Not rinsing soap still on dishes
try washing the dish washer out with a good drain unblocker the system gets cloated up with grease, then use a dishwasher salt with the washes this will help to remove the suds ets, most dishwashes have a compartment to put either liquid or solid dishwash aid in try a different aid, also if you use tablet form i desolve it first in hot water in a small container
then place that into the dishwaser on the lower shelf, that helps
Aug 16, 2009 | Dishwashers
KitchenAid Dishwasher Rinse Aid Clogged w/ Detergent
have you tried distilled vinagar? this may work for you.
Jul 29, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Where do I put Jet Dry?
IF your dishwasher has the capability for using JetDry, you will ind that on the door there is a plug thing that you remove and fill and replace it. The plug usually unscrews a quarter turn and then pulls out.
Jul 25, 2009 | Magic Chef Dishwashers
JetDry is leaking out, under the door
Well, I'll be glad to respond of they or you have questions.
If you would, reward me with a FixYa, and I'll be sure to respond on future requests on this unit, unless I am traveling. But I will get back with you.
Feb 04, 2009 | GE Nautilus 24" Built-in Dishwasher
Liquid Detergent in JetDry by nistake
You will nee to bring a hose in from out side or hook one up to the sink...and flush it out and let the DW drain it out ...or use a shop vac to **** out the soap and flush it with water...and shop vac the water out....Then fill the dispenser with water...and run it through as many cycles as required to clear all inappropriate fluids out.
Hope this helps.....good luck and good day...please rate my effort....the Fang.
Dec 26, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Disdwaser leaves spots on dishes
You simply need to use a product called Jetdry for a couple of weeks until all the traces of factory solvents etc. work out of the machine. Sometimes if you have a really high concentration of particulates in your water the problem will continue and that is what the Jetdry is for. It isn't the new dishwashers problem it is the local water. One permanent solution is to hook up a water purifier/softner in order to clean the water up. Jetdry is used in many areas and is perfectly safe. Good Luck this will help.
Nov 26, 2008 | Dishwashers
My son accidentally put dishwashing soap (for dishwashers) in the area where the jetdry stuff goes? Can this be corrected?
Hi ccarson004,
I'm Harvey the Master Plumber.
Your question is: Your son accidentally put dishwashing soap (for dishwashers) in the area where the jetdry stuff goes? Can this be corrected?
Yes, but I don't recomend this to the average homeowner because it requires taking the door apart. You might consider the Repair Directory for a repairman. You could just use the d/w, I don't think it will hurt anything and it will quickly flush itself out.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Dishwashers
Dishwashers Logo
252 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
