Question about Acer Aspire 5315 Notebook
Cannot see screen properly
The screen actually looks like it has impact marks on it.but the outer case is in perfect order and when you touch the screen there are no cracks..when the computer is turned on the screen looks like it has been smashed by a rock...sounds stupid but thats what it looks like
  • 535 Answers
U have to reinstall your garphics driver
Posted on Oct 03, 2008
    Problem Solver:
  • 6 Answers
Could it be a virus?? try running a comprehensive virus scan...
Posted on Sep 29, 2008
2 Suggested Answers
pankaj_dic
  • 1250 Answers
SOURCE: Cracked Screen??NO
this might be due to the dead pixels on the screen for this consult acer
How to make a 5 point star
Use a compass to draw a circle the size you want your star to be.
Draw a second, smaller circle inside the first, using the same center point. Make the second circle about half the size of the first.
Draw a line from the edge of the outer circle to the center point using a ruler.
Place a protractor on the line, with the center hole of the protractor over the center point of the circle.
Measure and mark every 72 degrees around the circle (72, 144, 216, 288 and 360 degrees), dividing the circle into five even sections.
Line the ruler up with the center point of the circle and one of the marks you just made.
Draw a line from the edge of the outer circle, through the center point, ending at the edge of the inner circle.
Continue drawing lines as described until you have drawn the five lines, which evenly divide the circle.
Connect the top of one of the lines that touches the outer circle to the lines that touch the inner circle on both sides, forming a point.
Continue to connect the lines around the circle until you have made a five-point star.
  • Make the inner circle larger for a fatter star or smaller for a thinner star.
  • Draw your star on poster board and cut it out to use as a pattern for drawing more.
  • To make a six-point star, measure and mark every 60 degrees (60, 120, 180, 240, 300, and 360 degrees), dividing the circle into six even sections.
  • To make an eight-point star, measure and mark every 45 degrees (45, 90, 135, 180, 225, 270, 315, and 360 degrees), dividing the circle into eight even sections.
  • Quick and easy may want to do this a few times before the final perfect one. This actually made me think. Haven't done geometry in a very long time.
Dec 23, 2014 | Cars & Trucks
My lcd screen is faded and hard to read on my perfect steam Electrolux washer. Would like to fix this my self if some one can tell me how? Thanks
Thanks for your post, friend!
I interpret that you would like to change out LCD screen on your Frigidaire washer. Typically, this is not a simple DIY job. I would recommend consulting with a professional technician for proper replacement of such electrical components to avoid any future issues. If you would like to order the part you should reach out to the manufacturer for the proper part number and price. Hopefully this has been helpful. -Matt
Oct 13, 2014 | Electrolux 4.2 Cu. Ft. Front Load Washer...
Electrolux Perfect steam washer has a faded lcd screen. Very hard to read at this point, can someone tell me how to order and replace it Please?
Thank you for your post, Glen Wagner!
In order to get proper replacement parts for your Electrolux washer you would need to have the model number available. I would recommend reaching out to the manufacturer, to guarantee the parts are correct. If you need assistance with installing the parts you may want to consult a professional for proper installation of replacement components. I hope this information has been beneficial. -Matt
Fresh out of the package I have 2 batteries not working.
check them with a multimeter. If they have the designated voltage then look elsewhere for the problem. Check the way they are put in. check that the negative actually touches the battery outer case
Jun 05, 2013 | BatteryShip Rayovac CR2032 Battery
Otter case for iphone has bubbles on the clear case
If you do have an "impact" series case for the 3G/3Gs, then it should simply be a matter of reapplying the clear film and being certain to flatten it slowly from one corner with a hard edge (credit card, etc...)
If by "clear case" you actually mean you have a "defender" series case, rub the phone's screen against your cheek. Get a good film of your natural skin on the screen and place it back in the case. The oil will separate your phone's screen from the case and cause for less bubbles.
Feb 20, 2011 | Apple Otter Box Impact Case 1943 For...
My o2 mobile screen not align model no. o2 [xda2s]
sounds like a faulty touch panel or if you have dropped it i know sometimes the casing bends and presses on the screen i have done many of these they are not easy to repair if you have to replace just the touch panel. but the casing can be pulled away from the screen. look around the front of the pda the corners are week and do bend in if there has been impact to the top or bottom corners.
Sep 19, 2009 | O2 Xda IIs Pocket PC
Screen locked on my htc mp6900. I don't know how to unlock it because the touch screen is not working. How do I get the touch screen to work?
You probably need to replace the digitizer pad. That's the outer screen. The actual touch screen. I did mine today, works great!! Easy to replace on your own,also. I got it for 11 dollars on dealxtreme.com good luck!!
Apr 20, 2009 | HTC Touch Cellular Phone
Re alligning the stylus
its one of two things
1) there is dirt under the edge of the screen. try to clean it out with a thin piece of card or a fine toothbrush
2) the screen has broken and you will need to repair or replace it. replacing the screen is hard but possible, I have done it once before when this problem happened, it does fix the problem.
there are 2 parts to the screen, the actual LCD itself and the overlay which senses where you are pressing. In this case its the overlay that is broken. It is not expensive to buy, but it is tricky to fit. You may break your DS trying. a google search should bring up videos on how to dismantle the DS.
Dec 01, 2008 | Nintendo DS Lite Console
Cracked Screen??NO
Sep 29, 2008 | Acer Aspire 5315 Notebook
Cracked laptop screen outer case at hinge
go to acspsrts.com and order whatever u want
Aug 12, 2008 | Computers & Internet
Acer Aspire 5315 Notebook Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
