Question about RIM BlackBerry 7290
No Service error message
My BB suddenly started displaying ' No Service' and refuses to connect to my wireless network and if at all by chance it does catch a network, the call lasts for like 5 seconds or lesser. PLEASE help !!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
Try performing a hard reset:
1. Remove the battery from the device (while it is still powered on).
2. Remove the SIM card from the device.
3. Reinsert the SIM card and battery back in to the device.
Posted on Oct 05, 2008
Can't connect to local WiFi Motorola router Msg:Unable to renew TCP/IP Address
Enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
Dec 27, 2012 | Belkin Wireless G USB Network Adapter -...
Internet crashes my htc Smart... Help?
The first time you use your device, the Connection Setup displays a notification message to inform you that it will automatically configure your device's data connections, such as 3G/GPRS/EDGE, WAP, and MMS.
  1. On the notification message, select Yes.
  2. If your SIM card supports multiple network operator profiles, the next message displays all network profile choices. Select the profile you want to use, then select OK. The Connection Setup configures your device's data connection settings.
  3. After the Connection Setup completes configuration, tap Restart. Tip: To choose the network operator manually, select Start > Settings > Connections tab > Connection Setup The GPRS/3G settings are preconfigured on your device when you applied for this service with your wireless network provider. If you need to add another GPRS/3G connection:
  4. Tap Start > Settings > Connections tab> Connections
  5. Under My ISP, tap Add a new modem connection
  6. On the Make New Connection screen, enter a name for the connection, select Cellular Line (GPRS, 3G) on the Select a modem list, then tap Next
  7. Enter the Access point name, then tap Next. You may obtain the access point name from your wireless service provider.
  8. When prompted, enter the user name and password. (Check with your wireless service provider if a user name and password are required to connect.)
  9. Tap Finish
Feb 09, 2012 | HTC Cell Phones
Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
Feb 26, 2010 | Acer Aspire One PC Notebook
Data connection refused
After cancelling the data plan with the wireless service provider, the message Data connection refused appears at the top of the Home screen on the BlackBerry smartphone instead of the branding of the wireless service provider.
This is caused may be you were previously subscribed to a data plan through a wireless service provider, and the BlackBerry smartphone is still configured to attempt to access the data network.
To resolve this issue, you need to turn off the Data Services feature on the BlackBerry smartphone. To perform this, you need to complete the following steps:
  1. From the Home screen, open the Options menu.
  2. Click on Mobile Network or Network.
  3. Set the value of the Data Services field to Off.
  4. Open the menu and select Save.
  5. Return to the Home screen.
  6. Turn the wireless transceiver off and then on again.
To enable (turn on) the wireless transceiver on the BlackBerry device, go to the Home screen and select the Turn Wireless On icon or open Manage Connections and select the wireless connection to be enabled. Once enabled, the icon will display Turn Wireless Off .
To disable (turn off) the wireless transceiver, go to the Home screen and select the Turn Wireless Off icon or open Manage Connections and select the wireless connect to be disabled. Once disabled, the icon will display Turn Wireless On.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
Wireless not working
First make sure the Wireless LAN card driver is installed. Then go to device manager and make sure the Wireless LAN card is enabled. If not, right click on the Wireless LAN card icon and select enable. Once that is done you should be able to search for wireless networks. If a wireless router is not broadcasting the SSID for the wireless network, the Wireless LAN card will not be able to locate the network during the search. If that is the case, you will need to set up the connection manually. If you can see the correct wireless network during the search but still can't connect to the network, it may not be an open network, so make sure you have the correct security settings for the network you want to connect to. If you did not set up the wireless network, you will need to get the security information from the network administrator.
Jun 10, 2008 | Everex StepNote NC1500 Notebook
Notebook wireless adapter
I will suggest 2 solutions
first you may uninstall and reinstall the driver of the Wireless Adapter. This has reasonable chance to fix the issue
Second solution is a bit more technical but you can try by following the instructions as has been explained; here is the link for the solution;
http://2brightsparks.com/bb/viewtopic.php?t=932
Jan 14, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
RIM BlackBerry 7290 Logo
118 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
